Kernel panic - not syncing: Fatal exception in interrupt
45 posts   Page 2 of 2   1, 2
by brain_spiller » Sat Jun 23, 2012 2:13 pm
Also getting this error message. Only had Pi up and running for 10mins so not sure if it's linked at all, but it seemed okay until I plugged in my powered external usb hard drive in, this would be recognised for a few seconds then disappear and a new pop up would appear saying a new device has been recognised, this happened over and over again.
Now after a few minutes of booting if I haven't managed to login to the desktop I get the error message, or if I manage to quickly login then the screen will appear frozen as the keyboard and mouse stop working, there doesn't seem to be any power running to my keyboard or mouse as infra red light is not on.
by dwilkin » Sat Jun 23, 2012 5:15 pm
Secretagent - no problems, but you'll have to give me instructions on how to use it, as I'm fairly new to this...
by brain_spiller » Mon Jun 25, 2012 1:58 pm
No longer getting this message. I had been using a Logitech cordless desktop EX 100 keyboard but without the cordless mouse (as it seems to eat up batteries). Once I unplugged my usb mouse and went back to the cordless seems to login to the desktop and run fine.
Although just discovered after about 3mins of the ethernet cable being plugged in it all locks up. :oops:
by brain_spiller » Mon Jun 25, 2012 3:01 pm
Sorry amendment to my post I only get this error when the ethernet cable is plugged in. Is this the same for everyone else? I connect to a Thompson TG585.
by abishur » Mon Jun 25, 2012 3:21 pm
Which distro are you using? What's the date of the image?
Dear forum: Play nice ;-)
Moderator
by brain_spiller » Mon Jun 25, 2012 3:59 pm
debian6-19-04-2012
by sudaraka » Mon Jun 25, 2012 4:13 pm
I have the same issue with archlinuxarm-29-04-2012.img even after the latest kernel upgrade it's the same.
by abishur » Mon Jun 25, 2012 4:40 pm
This post by Dom
viewtopic.php?f=28&t=8473&p=105514
might help you
Moderator
by dom » Tue Jun 26, 2012 3:44 pm
I've got a fix from Naren that hopefully fixes this issue. Should be available from github. e.g. use rpi-update.
Moderator
by alexandru.cucu » Tue Jun 26, 2012 3:55 pm
Thanks Naren, the keyboard is working perfectly :)
https://launchpad.net/~alexandru.cucu
by sudaraka » Wed Jun 27, 2012 12:49 am
Yay! Latest firmware update via rpi-update fixed it for me too \o/
I'm not sure who to thank for this exactly, but appreciate it very much.
by leon_heller » Thu Jun 28, 2012 2:42 pm
I'm using debian6-19-04-2012, and have a keyboard problem with the kernel panic error. How can the update be installed without a working keyboard?
Leon Heller
G1HSM
by dom » Thu Jun 28, 2012 2:46 pm
leon_heller wrote:I'm using debian6-19-04-2012, and have a keyboard problem with the kernel panic error. I don't see how the update can be installed without a working keyboard.
If you can boot (e.g. with another keyboard, or no keyboard and ssh in)
http://elinux.org/R-Pi_Troubleshooting# ... g_firmware
You could also try downloading kernel.img from here:
https://github.com/raspberrypi/firmware ... aster/boot
and replace the one on your sdcard with it. Then once booted, run rpi-update.
Moderator
by leon_heller » Thu Jun 28, 2012 2:51 pm
Thanks, Dom.
I've ordered a Trust ClassicLine keyboard which is one that is supposed to work without problems, and I should get it tomorrow. If it does work I'll try the update and see if the other keyboard works with it. I'll report back on what happens.
I tried that kernel from https://github.com/raspberrypi/firmware ... aster/boot. I still get an error caused by the keyboard, and it won't boot without it.
Leon Heller
G1HSM
by leon_heller » Fri Jun 29, 2012 2:51 pm
The Trust ClassicLine keyboard I ordered a couple of days ago has turned up, and that got the system working properly. The mouse also works.
Leon Heller
G1HSM
by BrockleyFox » Sun Jul 01, 2012 4:24 pm
Hi, I have the same keyboard problem. My PI will bot fine, until I plug in a keyboard, meaning obviously I cant "login", run rpi-updat or anything else. I have downloaded the new kernal.img from above, but i dont know how to transfer it to my sdhc card. When I try to "drag and drop" it, my PI then wont boot at all. If i use the win32 disk image program to write the new "kernal.img", my PI wont boot at all. I'm not sure what I need to do to get this working. Anyhelp would be very gratefully appreciated.
Sorry for sounding a bit dim witted, but i'm quite new to all this. Many thanks in advance.
by dom » Sun Jul 01, 2012 4:52 pm
@BrockleyFox
Yes, insert sdcard into windows machine. You should see the drive show up in explorer. It should contain a number of files, including kernel.img. Just copy/paste or drag'n'drop the newer kernel.img.
No need for win32image.
Moderator
by BrockleyFox » Sun Jul 01, 2012 5:55 pm
Hi Dom
I can't believe how stupid I have been. I actually tried dragging and dropping just the "kernal.img" file(with no success). It never occurred to me to drag and drop ALL the files. Doh!! lol
Anyway, everything is working perfectly now.... although the password doesn't seem to be "raspberry" for some reason. still, my keyboard is working, so i'm happy!
Many thanks. :)
by carbon14 » Wed Aug 08, 2012 8:36 am
I have this same problem with a PKBW11 PC World Essentials
This keyboard apparently works on Windows, but it does report itself via plug and play as a 'USB Keykoard'
I'm suspicious that this is a poorly implemented plug and play protocol, and that Windows copes with it better than the pi.
If it is a keyboard firmware issue, it's possible that there are many keyboards on the market with essentially the same firmware in them.
by carbon14 » Wed Aug 08, 2012 10:20 am
Just updated (using rpi-update).
The PC World Essentials PKBW11 now seems to work.
