I've tried 3 different monitors, 2 hdmi cables, couple of chargers and even played around with the config.txt, by using hdmi boost, hdmi_drive etc. without any luck. I also tried arch thinking that the debian image might be corrupt, but still no luck
Is it possible that i shorted out the Pi while disconnecting the power connector? The voltage on the multimeter reads 4.95V and the OK and PWR led are on.
Thanks.
