Do you think this should be good enough for the Pi?
http://www.amazon.co.uk/CHARGE.....038;sr=1-1
Would love for others to share their working power supply's and where they got them.
USB bus seems to be shutting down after 30seconds
Page 4 of 4 1, 2, 3, 4
Looks perfect to me, it doesn't say how long the cable is nor the output voltage, but I assume it'd be 5v.
The quality of the USB cable is the only real unknown.
On a clear disk one can seek forever
Ive ordered that along with a battery:
http://www.amazon.co.uk/exec/o.....os_product
Which has a 1amp and a 2.1amp output, in theory should power my pi for days.
I have an official HTC and Samsung (U2) USB to Micro cable so I dont think its the quality of cable, lets hope the quality of the charger is good enough!
DOUBLE POST, PLEASE DELETE
*Dam work internet connection!
Please, people, use the correct units.
Currents are measured (often) in milliamps: mA.
Battery capacities are measured (often) im milliamp-hours: mAh. That's current multiplied by time. For example, a 500 mAh battery should be able to supply 500 mA for one hour, or 250 mA for 2 hours, etc. (Caveats apply, I know, but I'm trying to keep it simple here.)
Sorry, the battery capacity is 7000mAh, 1 port provides 1000mA and the other 2100mA (is that right? im new to electricity terminology but im getting there!)
Am i right in saying that if the capacity is 7000mAh and the Pi requires a 700mA supply, if it used all that 700mA constantly it would last for 10 hours?
Helpme1986 said:
Yes you would be correct in theory, in practice you would get slightly less than that, but as a rule of thumb it is a good guide.
**edit** The above applies to an actual battery, I've just looked at your Amazon link, and in your case you will probably get very close to the theoretical 10 hours as there are electronic gubbins (technical term there) inside that case.
yeah of course, plus on the packaging it says 6600mAh (bit miss leading but never mind)
Will update the Wiki if should it work as I can image a few people wanting a totally portable Pi
After a night round my friends house (fellow geek) im 99% sure my Pi is faulty
At his we tried:
HTC 1A
Samsung 1A
Samsung 2A (Worked the best but still dropped, all of these with 3 different USB Cables, all official and not cheap)
A different router and ethernet cable
Different TV's and HDMI cables
4 different SD Cards (All booted the OS fine)
Different Keyboards and mice (with and without powered hub)
The best we could do was get it stable with the Samsung 2A supply and no ethernet, as soon as the ethernet plugged in it would drop regulary (but this time come back after a while which never happened before, but of course drop again)
I can only assume there is a bad solder on the board which the 2A supply is helping with (compared to the 700mAh) but ultimatly is still suffering.
What would the Foundation prefer? Given its a dev board do they want it back to do their own tests (happy to pay for postage each way) or just return to RS?
At his we tried:
HTC 1A
Samsung 1A
I don't know what the official policy is on returns, but if you can reach Pete Lomas [Liz - Pete's contact details redacted - he's just sent me a bewildered email about this, and it's really not something we want to be spending his time on because he is a *very* busy man!]]
Liz has mailed me back (Big thank you, i know how busy you are!) and said to return it to RS who will in turn send it back to them for testing
(though ill drop Pete a mail)
Just hope I dont have to wait to long for a replacement
I had similar problems - started with a iphone plug and usb cable with unpowered hub and moved to powered hub and ipad plug... drops usb when i have a wifi adapter, keybd, and mouse and hdmi runnig. All usb devices on the powered hub. I also noticed that I only have 192 Mb ram - anyone else short on ram?
Helpme1986 said:
It would be interesting to know the voltage at RasPi for each power supply. For example, a higher voltage could cause RG2 to run hotter which could cause a marginal F3 to misbehave. Only a hypothesis. I wonder how the software decides to shut down USB? It is monitoring the USB voltages on the USB ports?
Just wondering and hoping my comments might help the debug process.
RG2? What component are you referring to?
Boreatton Scouts said:
The GPU and CPU have different memory allocations:
We will supply 3 versions of the GPU firmware built for different split sizes (ARM with 128M, 192M and 224M). We hope to eventualy use CMA to handle dynamically moving the memory split, but that's a significant job that will take a while.
-from http://www.raspberrypi.org/for.....txt/page-3
I also noticed that I only have 192 Mb ram – anyone else short on ram?
bodgyuk said:
RG2 is the 3.3V regulator, which is physically located on the top side near the microUSB power connector. F3 is near that location but on the bottom side.. See also:
http://www.raspberrypi.org/wp-.....s-R1.0.pdf
http://itlounge.eu/wp-content/.....rry_Pi.jpg
So it is
Couldn't see RG designators anywhere on the schematic, and I was wearing my glasses.
I wonder if some small reverse diodes across out to in would be prudent.
bodgyuk said:
I was curious so I checked the ONsemi NCP1117 data sheet for RG2. In turns out it has a built-in protection diode which can withstand a 15A surge, so you usually do not need a separate external diode.
Wouldnt it be better to get a real switching power supply instead of trying phone chargers? Seems like alot of people are having problems using chargers.
You can get a good regulated ac to dc 5v 1.5 or 2a supply rather cheaply tho you might have to add your own mini usb connector.
