/var/log/syslog show a large number of these lines:
- Code: Select all
Jul 2 22:03:08 raspberrypi kernel: [ 2030.168080] usb 1-1.3: USB disconnect, device number 29
Jul 2 22:03:08 raspberrypi kernel: [ 2030.186746] sr0: scsi3-mmc drive: 0x/168x writer dvd-ram cd/rw cdda caddy
Jul 2 22:03:08 raspberrypi kernel: [ 2030.190569] sr 25:0:0:0: Attached scsi CD-ROM sr0
Jul 2 22:04:09 raspberrypi kernel: [ 2090.728379] usb 1-1.3: new high speed USB device number 30 using dwc_otg
Jul 2 22:04:09 raspberrypi kernel: [ 2090.829903] usb 1-1.3: New USB device found, idVendor=0930, idProduct=0b05
Jul 2 22:04:09 raspberrypi kernel: [ 2090.829939] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 2 22:04:09 raspberrypi kernel: [ 2090.829960] usb 1-1.3: Product: USB 2.0 CD + HDD
Jul 2 22:04:09 raspberrypi kernel: [ 2090.829976] usb 1-1.3: Manufacturer: Toshiba
Jul 2 22:04:09 raspberrypi kernel: [ 2090.830001] usb 1-1.3: SerialNumber: 11140600090D
Jul 2 22:04:09 raspberrypi kernel: [ 2090.844883] scsi26 : usb-storage 1-1.3:1.0
Jul 2 22:04:10 raspberrypi kernel: [ 2091.849548] scsi scan: INQUIRY result too short (5), using 36
Jul 2 22:04:10 raspberrypi kernel: [ 2091.849598] scsi 26:0:0:0: CD-ROM Toshiba USB 2.0 CD-ROM 1.14 PQ: 0 ANSI: 0
No /dev/sd* entries are available to mount. There is a /dev/sr0 but I cannot mount it.
The disk is not shown with "fdisk -l"
