It fails when auto-run during boot and when I try to run it myself, here's what I get:
- Code: Select all
pi@raspberrypi / $ sudo resize2fs /dev/mmcblk0p2
resize2fs 1.42.5 (29-Jul-2012)
Filesystem at /dev/mmcblk0p2 is mounted on /; on-line resizing required
old_desc_blocks = 1, new_desc_blocks = 1
Performing an on-line resize of /dev/mmcblk0p2 to 1928064 (4k) blocks.
resize2fs: Invalid argument While trying to add group #25
On the previous Raspbian release, the resize worked fine.
Any ideas what I can do on Raspi to fix this?
UPDATE:
WHoops... I forgot to add some data.
Here's what kernel log says at the moment resize2fs runs:
- Code: Select all
[23124.124601] EXT4-fs warning (device mmcblk0p2): verify_reserved_gdb:669: reserved GDT 4 missing grp 1 (32772)
[23128.328878] EXT4-fs warning (device mmcblk0p2): verify_reserved_gdb:669: reserved GDT 4 missing grp 1 (32772)
[23143.056075] EXT4-fs warning (device mmcblk0p2): verify_reserved_gdb:669: reserved GDT 4 missing grp 1 (32772)
[23147.122204] EXT4-fs warning (device mmcblk0p2): verify_reserved_gdb:669: reserved GDT 4 missing grp 1 (32772)
Running resize2fs with the debug argument doesn't produce any extra information.
Here's output of strace:
- Code: Select all
pi@raspberrypi / $ sudo strace resize2fs /dev/mmcblk0p2
execve("/sbin/resize2fs", ["resize2fs", "/dev/mmcblk0p2"], [/* 15 vars */]) = 0
brk(0) = 0x8df000
uname({sys="Linux", node="raspberrypi", ...}) = 0
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6fa2000
access("/etc/ld.so.preload", R_OK) = 0
open("/etc/ld.so.preload", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=44, ...}) = 0
mmap2(NULL, 44, PROT_READ|PROT_WRITE, MAP_PRIVATE, 3, 0) = 0xb6fa1000
close(3) = 0
open("/usr/lib/arm-linux-gnueabihf/libcofi_rpi.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\10\4\0\0004\0\0\0"..., 512) = 512
lseek(3, 3456, SEEK_SET) = 3456
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1240) = 1240
lseek(3, 2537, SEEK_SET) = 2537
read(3, "A.\0\0\0aeabi\0\1$\0\0\0\0056\0\6\6\10\1\t\1\n\2\22\4\24\1\25"..., 47) = 47
fstat64(3, {st_mode=S_IFREG|0755, st_size=7332, ...}) = 0
mmap2(NULL, 35276, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6f76000
mprotect(0xb6f77000, 28672, PROT_NONE) = 0
mmap2(0xb6f7e000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0) = 0xb6f7e000
close(3) = 0
munmap(0xb6fa1000, 44) = 0
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=53987, ...}) = 0
mmap2(NULL, 53987, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb6f68000
close(3) = 0
open("/lib/arm-linux-gnueabihf/libe2p.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\250\25\0\0004\0\0\0"..., 512) = 512
lseek(3, 25932, SEEK_SET) = 25932
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1040) = 1040
lseek(3, 25640, SEEK_SET) = 25640
read(3, "A0\0\0\0aeabi\0\1&\0\0\0\0056\0\6\6\10\1\t\1\n\2\22\4\24\1\25"..., 49) = 49
fstat64(3, {st_mode=S_IFREG|0644, st_size=26972, ...}) = 0
mmap2(NULL, 58908, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6f59000
mprotect(0xb6f5f000, 28672, PROT_NONE) = 0
mmap2(0xb6f66000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5) = 0xb6f66000
close(3) = 0
open("/lib/arm-linux-gnueabihf/libext2fs.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\374\250\0\0004\0\0\0"..., 512) = 512
lseek(3, 227780, SEEK_SET) = 227780
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1120) = 1120
lseek(3, 227460, SEEK_SET) = 227460
fstat64(3, {st_mode=S_IFREG|0644, st_size=228900, ...}) = 0
mmap2(NULL, 260740, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6f19000
mprotect(0xb6f50000, 28672, PROT_NONE) = 0
mmap2(0xb6f57000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x36) = 0xb6f57000
close(3) = 0
open("/lib/arm-linux-gnueabihf/libcom_err.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\234\17\0\0004\0\0\0"..., 512) = 512
lseek(3, 8712, SEEK_SET) = 8712
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1080) = 1080
lseek(3, 8408, SEEK_SET) = 8408
fstat64(3, {st_mode=S_IFREG|0644, st_size=9792, ...}) = 0
mmap2(NULL, 41228, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6f0e000
mprotect(0xb6f10000, 28672, PROT_NONE) = 0
mmap2(0xb6f17000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1) = 0xb6f17000
close(3) = 0
open("/lib/arm-linux-gnueabihf/libgcc_s.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0`\364\0\0004\0\0\0"..., 512) = 512
lseek(3, 130212, SEEK_SET) = 130212
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1160) = 1160
lseek(3, 129880, SEEK_SET) = 129880
read(3, "A2\0\0\0aeabi\0\1(\0\0\0\0056\0\6\6\10\1\t\1\n\2\22\4\24\1\25"..., 51) = 51
fstat64(3, {st_mode=S_IFREG|0644, st_size=131372, ...}) = 0
mmap2(NULL, 162704, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6ee6000
mprotect(0xb6f06000, 28672, PROT_NONE) = 0
mmap2(0xb6f0d000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1f) = 0xb6f0d000
close(3) = 0
open("/lib/arm-linux-gnueabihf/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\214y\1\0004\0\0\0"..., 512) = 512
lseek(3, 1194784, SEEK_SET) = 1194784
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1360) = 1360
lseek(3, 1194348, SEEK_SET) = 1194348
fstat64(3, {st_mode=S_IFREG|0755, st_size=1196144, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6fa1000
mmap2(NULL, 1238312, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6db7000
mprotect(0xb6ed9000, 28672, PROT_NONE) = 0
mmap2(0xb6ee0000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x121) = 0xb6ee0000
mmap2(0xb6ee3000, 9512, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb6ee3000
close(3) = 0
open("/lib/arm-linux-gnueabihf/libpthread.so.0", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\274V\0\0004\0\0\0"..., 512) = 512
lseek(3, 82712, SEEK_SET) = 82712
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1400) = 1400
lseek(3, 82308, SEEK_SET) = 82308
fstat64(3, {st_mode=S_IFREG|0755, st_size=116462, ...}) = 0
mmap2(NULL, 123412, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6d98000
mprotect(0xb6dac000, 28672, PROT_NONE) = 0
mmap2(0xb6db3000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x13) = 0xb6db3000
mmap2(0xb6db5000, 4628, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb6db5000
close(3) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6fa0000
set_tls(0xb6fa04c0, 0xb6fa0bb8, 0xb6fa5048, 0xb6fa04c0, 0xb6fa5048) = 0
mprotect(0xb6db3000, 4096, PROT_READ) = 0
mprotect(0xb6ee0000, 8192, PROT_READ) = 0
mprotect(0xb6f17000, 4096, PROT_READ) = 0
mprotect(0xb6f57000, 4096, PROT_READ) = 0
mprotect(0xb6f66000, 4096, PROT_READ) = 0
mprotect(0x1a000, 4096, PROT_READ) = 0
mprotect(0xb6fa4000, 4096, PROT_READ) = 0
munmap(0xb6f68000, 53987) = 0
set_tid_address(0xb6fa0068) = 2895
set_robust_list(0xb6fa0070, 0xc) = 0
futex(0xbe94a828, FUTEX_WAIT_BITSET_PRIVATE|FUTEX_CLOCK_REALTIME, 1, NULL, b6db4000) = -1 EAGAIN (Resource temporarily unavailable)
rt_sigaction(SIGRTMIN, {0xb6d9d20c, [], SA_SIGINFO|0x4000000}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0xb6d9d0b4, [], SA_RESTART|SA_SIGINFO|0x4000000}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM_INFINITY}) = 0
open("/usr/lib/locale/locale-archive", O_RDONLY|O_LARGEFILE) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=3203536, ...}) = 0
mmap2(NULL, 2097152, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb6b98000
mmap2(NULL, 1179648, PROT_READ, MAP_PRIVATE, 3, 0x1b6) = 0xb6a78000
brk(0) = 0x8df000
brk(0x900000) = 0x900000
close(3) = 0
write(2, "resize2fs 1.42.5 (29-Jul-2012)\n", 31resize2fs 1.42.5 (29-Jul-2012)
) = 31
stat64("/dev/mmcblk0p2", {st_mode=S_IFBLK|S_ISVTX|0660, st_rdev=makedev(179, 2), ...}) = 0
open("/proc/swaps", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0444, st_size=0, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6a77000
read(3, "Filename\t\t\t\tType\t\tSize\tUsed\tPrio"..., 1024) = 95
stat64("/var/swap", {st_mode=S_IFREG|0600, st_size=104857600, ...}) = 0
read(3, "", 1024) = 0
close(3) = 0
munmap(0xb6a77000, 4096) = 0
open("/proc/mounts", O_RDONLY) = 3
futex(0xb6ee3b94, FUTEX_WAKE_PRIVATE, 2147483647) = 0
read(3, "rootfs / rootfs rw 0 0\n/dev/root"..., 1024) = 711
stat64("/dev/root", {st_mode=S_IFBLK|S_ISVTX|0660, st_rdev=makedev(179, 2), ...}) = 0
stat64("/", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/.ismount-test-file", O_RDWR|O_CREAT, 0600) = 4
close(4) = 0
unlink("/.ismount-test-file") = 0
close(3) = 0
open("/dev/mmcblk0p2", O_RDONLY|O_EXCL) = -1 EBUSY (Device or resource busy)
open("/dev/mmcblk0p2", O_RDWR|O_LARGEFILE) = 3
fstat64(3, {st_mode=S_IFBLK|S_ISVTX|0660, st_rdev=makedev(179, 2), ...}) = 0
close(3) = 0
open("/dev/mmcblk0p2", O_RDONLY|O_LARGEFILE) = 3
ioctl(3, BLKDISCARDZEROES, 0xbe94a450) = 0
lseek(3, 1024, SEEK_SET) = 1024
read(3, "\0 \3\0\0\200\f\0\342\237\0\0\f\0\0\0}\235\1\0\0\0\0\0\2\0\0\0\2\0\0\0"..., 1024) = 1024
lseek(3, 4096, SEEK_SET) = 4096
read(3, "q\0\0\0\201\0\0\0\221\0\0\0\0\0\1\0\303\3\4\0\0\0\0\0\0\0\0\0\0\0\206\250"..., 4096) = 4096
open("/dev/mmcblk0p2", O_RDONLY|O_LARGEFILE) = 4
ioctl(4, BLKGETSIZE64, 0xbe94a4a0) = 0
close(4) = 0
open("/usr/share/locale/locale.alias", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=2570, ...}) = 0
read(4, "# Locale name alias data base.\n#"..., 4096) = 2570
read(4, "", 4096) = 0
close(4) = 0
open("/usr/share/locale/sr_RS/LC_MESSAGES/e2fsprogs.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/share/locale/sr/LC_MESSAGES/e2fsprogs.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
fstat64(1, {st_mode=S_IFCHR|0620, st_rdev=makedev(136, 0), ...}) = 0
write(1, "Filesystem at /dev/mmcblk0p2 is "..., 72Filesystem at /dev/mmcblk0p2 is mounted on /; on-line resizing required
) = 72
write(1, "old_desc_blocks = 1, new_desc_bl"..., 41old_desc_blocks = 1, new_desc_blocks = 1
) = 41
open("/", O_RDONLY) = 4
ioctl(4, 0x40086610, 0xbe94a708) = -1 EINVAL (Invalid argument)
ioctl(4, 0x40046607, 0xbe94a624) = 0
gettimeofday({1357289798, 596886}, NULL) = 0
brk(0x925000) = 0x925000
gettimeofday({1357289798, 602284}, NULL) = 0
lseek(3, 462848, SEEK_SET) = 462848
read(3, "\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377"..., 4096) = 4096
lseek(3, 528384, SEEK_SET) = 528384
lseek(3, 466944, SEEK_SET) = 466944
lseek(3, 532480, SEEK_SET) = 532480
lseek(3, 471040, SEEK_SET) = 471040
lseek(3, 536576, SEEK_SET) = 536576
lseek(3, 475136, SEEK_SET) = 475136
lseek(3, 540672, SEEK_SET) = 540672
lseek(3, 479232, SEEK_SET) = 479232
lseek(3, 544768, SEEK_SET) = 544768
lseek(3, 483328, SEEK_SET) = 483328
lseek(3, 548864, SEEK_SET) = 548864
lseek(3, 487424, SEEK_SET) = 487424
lseek(3, 552960, SEEK_SET) = 552960
lseek(3, 491520, SEEK_SET) = 491520
lseek(3, 557056, SEEK_SET) = 557056
lseek(3, 495616, SEEK_SET) = 495616
lseek(3, 561152, SEEK_SET) = 561152
lseek(3, 499712, SEEK_SET) = 499712
lseek(3, 565248, SEEK_SET) = 565248
read(3, "\377\377\377\377\377\374\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377\377"..., 4096) = 4096
lseek(3, 503808, SEEK_SET) = 503808
lseek(3, 569344, SEEK_SET) = 569344
lseek(3, 507904, SEEK_SET) = 507904
lseek(3, 573440, SEEK_SET) = 573440
lseek(3, 512000, SEEK_SET) = 512000
lseek(3, 516096, SEEK_SET) = 516096
lseek(3, 1879048192, SEEK_SET) = 1879048192
lseek(3, 1879052288, SEEK_SET) = 1879052288
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 4096) = 4096
lseek(3, 2013265920, SEEK_SET) = 2013265920
lseek(3, 2013270016, SEEK_SET) = 2013270016
_llseek(3, 2147483648, [2147483648], SEEK_SET) = 0
_llseek(3, 2147487744, [2147487744], SEEK_SET) = 0
_llseek(3, 2281701376, [2281701376], SEEK_SET) = 0
_llseek(3, 2281705472, [2281705472], SEEK_SET) = 0
read(3, "\377\377\377\377\377\t\0\0@\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0 \0\210\f\200"..., 4096) = 4096
_llseek(3, 2415919104, [2415919104], SEEK_SET) = 0
_llseek(3, 2415923200, [2415923200], SEEK_SET) = 0
_llseek(3, 2550136832, [2550136832], SEEK_SET) = 0
_llseek(3, 2550140928, [2550140928], SEEK_SET) = 0
_llseek(3, 2684354560, [2684354560], SEEK_SET) = 0
_llseek(3, 2684358656, [2684358656], SEEK_SET) = 0
_llseek(3, 2818572288, [2818572288], SEEK_SET) = 0
_llseek(3, 2818576384, [2818576384], SEEK_SET) = 0
_llseek(3, 2952790016, [2952790016], SEEK_SET) = 0
_llseek(3, 2952794112, [2952794112], SEEK_SET) = 0
_llseek(3, 3087007744, [3087007744], SEEK_SET) = 0
_llseek(3, 3087011840, [3087011840], SEEK_SET) = 0
_llseek(3, 3221225472, [3221225472], SEEK_SET) = 0
_llseek(3, 3221229568, [3221229568], SEEK_SET) = 0
gettimeofday({1357289798, 820967}, NULL) = 0
gettimeofday({1357289798, 822662}, NULL) = 0
brk(0x94c000) = 0x94c000
mmap2(NULL, 245760, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6a3b000
write(1, "Performing an on-line resize of "..., 71Performing an on-line resize of /dev/mmcblk0p2 to 1928064 (4k) blocks.
) = 71
ioctl(4, 0x40186608, 0xbe94a608) = -1 ENOTTY (Inappropriate ioctl for device)
ioctl(4, 0x40286608, 0xbe94a5e0) = -1 EINVAL (Invalid argument)
write(2, "resize2fs", 9resize2fs) = 9
write(2, ": ", 2: ) = 2
open("/usr/share/locale/sr_RS/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/share/locale/sr/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory)
write(2, "Invalid argument", 16Invalid argument) = 16
write(2, " ", 1 ) = 1
write(2, "While trying to add group #25", 29While trying to add group #25) = 29
ioctl(2, SNDCTL_TMR_TIMEBASE or TCGETS, {B38400 opost isig icanon echo ...}) = 0
write(2, "\n", 1
) = 1
exit_group(1) = ?
