Red Light
Page 1 of 2 1, 2
I have tried numerous images for my pi but i get a lot of red lights and no booting. It only happens on certain images like debian squeeze, pwnpi, and a few others. I know its not my SD cards as i can run other images like xbian and rasbmc. Tried different programs to flash the images like win32diskimager, fedora arm installer, etc. Any help would be appreciated.
Getphazed wrote:I have tried numerous images for my pi but i get a lot of red lights and no booting. It only happens on certain images like debian squeeze, pwnpi, and a few others. I know its not my SD cards as i can run other images like xbian and rasbmc. Tried different programs to flash the images like win32diskimager, fedora arm installer, etc. Any help would be appreciated.
so what's the problem?
some work - use those
what exactly are you wanting to put on your SD card
1QC43qbL5FySu2Pi51vGqKqxy3UiJgukSX - Prosliver FTW
If i wanted to stick with the images that worked i wouldn't have posted asking for help. Trying to use images like debian squeeze, pwnpi, magnimpi. My problem is when i flash them to an sd card and i put it in the pi and power it up i only get a red light, so im looking for a solution. Maybe its a issue with the image, maybe with the way im flashing it.
If one image works, then all the standard ones should work! I would still be suspicious of the SD card or the way that the SD card image is being written.
I had problems at one point due to the SD Writer hardware I was using. I fixed that by getting one of these USB based SD card adapters (I am told you can get an equivalent even cheaper from Poundland if you have one near you). The given adapter also works well in the Pi which is useful you want to write images there.
Have you tried the latest Raspbian image from the Download section?
My Raspberry Pi blog and home of the BerryClip Add-on board : http://www.raspberrypi-spy.co.uk/
Using a few different writers and sd cards. Using a lexar micro sd card reader with a couple micro sd cards, a sony multi card reader with sd cards which im using a couple different ones, and on my laptop using the card reader with sd cards and microsd cards with adapter. Im thinking it might be the images or the software writing the images, but i cant be the only one having this issue.
As for raspbian some of the software i want to use wont run on it, which is why i want to use squeeze.
Is it always 100% consistent that some distros work and some distros do not?
When you say no booting does that mean nothing appears on the screen at all?
Ya i get nothing but a sold red light, nothing on the screen, which leads me to believe its an issue with the image on the sd. Just wondering if im doing something wrong when i flash it since from what i have seen other people are able to use the same images.
lets take one
with the latest wheezy you have
1) extracted the .zip file
2) written this to the SD ard
3) booted off it
what files and partition sizes do you see from windows ?
3) booted off it
I downloaded wheezy, setup with win32diskimager, booted it up. Attached images is what you asked for.
Hello
I am having exactly the same problem, red light on Raspberry Pi, but does not boot, will try another SD card, have you had any success, thank you.
I tried the PwnPi SD card in my other RaspberryPi this is the 256 mb model and it worked, even after updating the 512 mb model it still does not work, thank you.
So it worked on the 256 board but not the 512? I haven't managed to get mine working yet.
I have the exact same problem with pwnpi. I have to Pis (256 and 512MB). And two SDCards.
Archlinux works on both cards and both pis. pwnpi (now it gets crazy) used to work but now I get a short glimpse of the green LED and then it stays red.
Anybody has an idea why this is happening?
bump
Having the same issue on the card I just received today. Anyone find a solution yet?
If its a card that came pre flashed it will more than likely need to be flashed with a newer release of the distro.
I've tried three different SD Cards (all class 4 and up and all 4 GB and up) with different (Current) distros. I have tried two power supplies and checked the power with a multi/meter (all after having issues with the SD cards and OSs) and checked the pins of the SD Card slot. Nothing seems to be out of the ordinary on the board and the cards are all new. All voltage and current readings are fine. I dont know what the problem could be.
BTW: I set up all three SD cards myself, using the raspi wiki step by step for installing from linux command line. I double checked every step prior to execution. I did install to the device (sdb) not a partition of (as in sdb1). Any thoughts? Im about to rage myself into taking a hammer to my new... thing thats not even heavy enough to be a paper weight.
Do you have hdmi and network cables plugged in? And are you using a hdmi converter or hdmi to hdmi?
Yes to the cables, and hdmi to hdmi
VinceBrowning what distro are you talking about Raspbian or Pwnpi, thank you.
I've been attempting raspbian and some of the others from the raspberrypi.org download page.
Maybe you have a faulty board, do you know someone that has set-up their on board?
Unfortunately I'm in the military and not anywhere near any friends who are remotely interested in tech. Forums and manuals are the only help I am privy to.
I'm thankful for your help, even though its not what I want to hear. Unfortunately I'm probably not going to be able to let it go with my recently acquired anger issues... Hammer time it is.
