raspi-config contains empty filename
by plus » Mon Nov 05, 2012 2:15 pm
Hi there!
After I was installing something I didn't get apt-get update or any install working anymore...I always get:
----- dpkg: unrecoverable fatal error, aborting: files list file for package "raspi-config" contains empty filename
E: Sub-process /usr/bin/dpkg returned an error code (2) ------
I'm stuck here :( anyone could please help me with this??
thanx so much,
plus
by plus » Tue Nov 06, 2012 10:41 am
no help? :(
by pluggy » Tue Nov 06, 2012 11:04 am
If it were me, I'd pull off the stuff in /etc I'd tweaked and reburn the image on the SD card. Often the easiest way with a mangled file system.
by plus » Tue Nov 06, 2012 11:27 am
I'd prefer to try something before doing this... I had a lot of stuff already configured....what about trying to replace only the file raspi-config??
by RaTTuS » Tue Nov 06, 2012 11:29 am
what did you install
how did you install it
what do the package files look like
what does raspi-config script look like
1QC43qbL5FySu2Pi51vGqKqxy3UiJgukSX - Prosliver FTW
by plus » Tue Nov 06, 2012 12:13 pm
let me see...
I made this:
- sudo apt-get install python python-pycurl python-crypto unrar tesseract-ocr tesseract-ocr-eng
then BY MISTAKE I made on another line:
- python-imaging spidermonkey-bin
then:
- sudo dpkg -i pyload-cli.deb
my raspi-config copy and paste:
#!/bin/sh
# Part of raspi-config http://github.com/asb/raspi-config
# See LICENSE file for copyright and license details
ASK_TO_REBOOT=0
do_info() {
whiptail --msgbox "\
This tool provides a straight-forward way of doing initial
configuration of the Raspberry Pi. Although it can be run
at any time, some of the options may have difficulties if
you have heavily customised your installation.\
" 20 70 1
do_expand_rootfs() {
# Get the starting offset of the root partition
PART_START=$(parted /dev/mmcblk0 -ms unit s p | grep "^2" | cut -f 2 -d:)
[ "$PART_START" ] || return 1
# Return value will likely be error for fdisk as it fails to reload the
# partition table because the root fs is mounted
fdisk /dev/mmcblk0 <<EOF
p
d
2
n
p
2
$PART_START
p
w
EOF
ASK_TO_REBOOT=1
# now set up an init.d script
cat <<\EOF > /etc/init.d/resize2fs_once &&
#!/bin/sh
### BEGIN INIT INFO
# Provides: resize2fs_once
# Required-Start:
# Required-Stop:
# Default-Start: 2 3 4 5 S
# Default-Stop:
# Short-Description: Resize the root filesystem to fill partition
# Description:
### END INIT INFO
. /lib/lsb/init-functions
case "$1" in
start)
log_daemon_msg "Starting resize2fs_once" &&
resize2fs /dev/mmcblk0p2 &&
rm /etc/init.d/resize2fs_once &&
update-rc.d resize2fs_once remove &&
log_end_msg $?
echo "Usage: $0 start" >&2
exit 3
esac
EOF
chmod +x /etc/init.d/resize2fs_once &&
update-rc.d resize2fs_once defaults &&
whiptail --msgbox "Root partition has been resized.\n\
The filesystem will be enlarged upon the next reboot" 20 60 2
set_config_var() {
lua - "$1" "$2" "$3" <<EOF > "$3.bak"
local key=assert(arg[1])
local value=assert(arg[2])
local fn=assert(arg[3])
local file=assert(io.open(fn))
local made_change=false
for line in file:lines() do
if line:match("^#?%s*"..key.."=.*$") then
line=key.."="..value
made_change=true
end
print(line)
end
if not made_change then
print(key.."="..value)
end
EOF
mv "$3.bak" "$3"
get_config_var() {
lua - "$1" "$2" <<EOF
local fn=assert(arg[2])
local val = line:match("^#?%s*"..key.."=(.*)$")
if (val ~= nil) then
print(val)
break
end
end
EOF
# $1 is 0 to disable overscan, 1 to disable it
set_overscan() {
# Stop if /boot is not a mountpoint
if ! mountpoint -q /boot; then
return 1
fi
[ -e /boot/config.txt ] || touch /boot/config.txt
if [ "$1" -eq 0 ]; then # disable overscan
sed /boot/config.txt -i -e "s/^overscan_/#overscan_/"
set_config_var disable_overscan 1 /boot/config.txt
else # enable overscan
set_config_var disable_overscan 0 /boot/config.txt
fi
do_overscan() {
whiptail --yesno "What would you like to do with overscan" 20 60 2 \
--yes-button Disable --no-button Enable
RET=$?
if [ $RET -eq 0 ] || [ $RET -eq 1 ]; then
ASK_TO_REBOOT=1
set_overscan $RET;
else
return 1
fi
do_change_pass() {
whiptail --msgbox "You will now be asked to enter a new password for the pi user" 20 60 1
passwd pi &&
whiptail --msgbox "Password changed successfully" 20 60 1
do_configure_keyboard() {
dpkg-reconfigure keyboard-configuration &&
printf "Reloading keymap. This may take a short while\n" &&
invoke-rc.d keyboard-setup start
do_change_locale() {
dpkg-reconfigure locales
do_change_timezone() {
dpkg-reconfigure tzdata
do_memory_split() {
if [ -e /boot/start_cd.elf ]; then
# New-style memory split setting
return 1
fi
## get current memory split from /boot/config.txt
CUR_GPU_MEM=$(get_config_var gpu_mem /boot/config.txt)
[ -z "$CUR_GPU_MEM" ] && CUR_GPU_MEM=64
## ask users what gpu_mem they want
NEW_GPU_MEM=$(whiptail --inputbox "How much memory should the GPU have? e.g. 16/32/64/128/256" \
20 70 "$CUR_GPU_MEM" 3>&1 1>&2 2>&3)
if [ $? -eq 0 ]; then
set_config_var gpu_mem "$NEW_GPU_MEM" /boot/config.txt
ASK_TO_REBOOT=1
fi
else # Old firmware so do start.elf renaming
get_current_memory_split
MEMSPLIT=$(whiptail --menu "Set memory split.\n$MEMSPLIT_DESCRIPTION" 20 60 10 \
"240" "240MiB for ARM, 16MiB for VideoCore" \
"224" "224MiB for ARM, 32MiB for VideoCore" \
"192" "192MiB for ARM, 64MiB for VideoCore" \
"128" "128MiB for ARM, 128MiB for VideoCore" \
3>&1 1>&2 2>&3)
set_memory_split ${MEMSPLIT}
ASK_TO_REBOOT=1
fi
fi
get_current_memory_split() {
return 1
fi
AVAILABLE_SPLITS="128 192 224 240"
MEMSPLIT_DESCRIPTION=""
for SPLIT in $AVAILABLE_SPLITS;do
if [ -e /boot/arm${SPLIT}_start.elf ] && cmp /boot/arm${SPLIT}_start.elf /boot/start.elf >/dev/null 2>&1;then
CURRENT_MEMSPLIT=$SPLIT
MEMSPLIT_DESCRIPTION="Current: ${CURRENT_MEMSPLIT}MiB for ARM, $((256 - $CURRENT_MEMSPLIT))MiB for VideoCore"
break
fi
done
set_memory_split() {
cp -a /boot/arm${1}_start.elf /boot/start.elf
sync
do_overclock() {
Be aware that overclocking may reduce the lifetime of your
Raspberry Pi. If overclocking at a certain level causes
system instability, try a more modest overclock. Hold down
shift during boot to temporarily disable overclock.
See http://elinux.org/RPi_Overclocking for more information.\
" 20 70 1
OVERCLOCK=$(whiptail --menu "Chose overclock preset" 20 60 10 \
"None" "700MHz ARM, 250MHz core, 400MHz SDRAM, 0 overvolt" \
"Modest" "800MHz ARM, 250MHz core, 400MHz SDRAM, 0 overvolt" \
"Medium" "900MHz ARM, 250MHz core, 450MHz SDRAM, 2 overvolt" \
"High" "950MHz ARM, 250MHz core, 450MHz SDRAM, 6 overvolt" \
"Turbo" "1000MHz ARM, 500MHz core, 600MHz SDRAM, 6 overvolt" \
3>&1 1>&2 2>&3)
case "$OVERCLOCK" in
None)
set_overclock None 700 250 400 0
Modest)
set_overclock Modest 800 250 400 0
Medium)
set_overclock Medium 900 250 450 2
High)
set_overclock High 950 250 450 6
Turbo)
whiptail --msgbox "Warning: some people have reported SD card corruption with this level of overclock." \
20 70 1
[ $? -ne 0 ] && return 1
set_overclock Turbo 1000 500 600 6
whiptail --msgbox "Programmer error, unrecognised overclock preset" 20 60 2
return 1
esac
ASK_TO_REBOOT=1
fi
set_overclock() {
set_config_var arm_freq $2 /boot/config.txt &&
set_config_var core_freq $3 /boot/config.txt &&
set_config_var sdram_freq $4 /boot/config.txt &&
set_config_var over_voltage $5 /boot/config.txt &&
cat <<\EOF > /etc/init.d/switch_cpu_governor &&
#!/bin/sh
### BEGIN INIT INFO
# Provides: switch_cpu_governor
# Required-Start: udev mountkernfs $remote_fs
# Required-Stop:
# Default-Start: S
# Default-Stop:
# Short-Description: Switch to ondemand cpu governor (unless shift key is pressed)
# Description:
### END INIT INFO
case "$1" in
start)
log_daemon_msg "Checking if shift key is held down"
timeout 1 thd --dump /dev/input/event* | grep -q "LEFTSHIFT\|RIGHTSHIFT"
printf " Yes. Not switching scaling governor"
log_end_msg 0
else
SYS_CPUFREQ_GOVERNOR=/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
[ -e $SYS_CPUFREQ_GOVERNOR ] && echo "ondemand" > $SYS_CPUFREQ_GOVERNOR
printf " No. Switching to ondemand scaling governor"
log_end_msg 0
fi
exit 3
esac
EOF
chmod +x /etc/init.d/switch_cpu_governor &&
update-rc.d switch_cpu_governor defaults &&
whiptail --msgbox "Set overclock to preset '$1'" 20 60 2
do_ssh() {
if [ -e /var/log/regen_ssh_keys.log ] && ! grep -q "^finished" /var/log/regen_ssh_keys.log; then
whiptail --msgbox "Initial ssh key generation still running. Please wait and try again." 20 60 2
return 1
fi
whiptail --yesno "Would you like the SSH server enabled or disabled?" 20 60 2 \
--yes-button Enable --no-button Disable
RET=$?
if [ $RET -eq 0 ]; then
update-rc.d ssh enable &&
invoke-rc.d ssh start &&
whiptail --msgbox "SSH server enabled" 20 60 1
elif [ $RET -eq 1 ]; then
update-rc.d ssh disable &&
whiptail --msgbox "SSH server disabled" 20 60 1
else
return $RET
fi
do_boot_behaviour() {
if [ -e /etc/init.d/lightdm ]; then
whiptail --yesno "Should we boot straight to desktop?" 20 60 2
RET=$?
if [ $RET -eq 0 ]; then # yes
update-rc.d lightdm enable 2
sed /etc/lightdm/lightdm.conf -i -e "s/^#autologin-user=.*/autologin-user=pi/"
ASK_TO_REBOOT=1
elif [ $RET -eq 1 ]; then # no
update-rc.d lightdm disable 2
ASK_TO_REBOOT=1
else # user hit escape
return 1
fi
else
whiptail --msgbox "Do sudo apt-get install lightdm to allow configuration of boot to desktop" 20 60 2
return 1
fi
do_update() {
apt-get update &&
apt-get install raspi-config &&
printf "Sleeping 5 seconds before reloading raspi-config\n" &&
sleep 5 &&
exec raspi-config
do_finish() {
if [ -e /etc/profile.d/raspi-config.sh ]; then
rm -f /etc/profile.d/raspi-config.sh
sed -i /etc/inittab \
-e "s/^#\(.*\)#\s*RPICFG_TO_ENABLE\s*/\1/" \
-e "/#\s*RPICFG_TO_DISABLE/d"
telinit q
fi
if [ $ASK_TO_REBOOT -eq 1 ]; then
whiptail --yesno "Would you like to reboot now?" 20 60 2
if [ $? -eq 0 ]; then # yes
sync
reboot
fi
fi
exit 0
# Command line options for non-interactive use
for i in $*
do
case $i in
--memory-split)
OPT_MEMORY_SPLIT=GET
printf "Not currently supported\n"
exit 1
--memory-split=*)
OPT_MEMORY_SPLIT=`echo $i | sed 's/[-a-zA-Z0-9]*=//'`
exit 1
# unknown option
esac
done
#if [ "GET" = "${OPT_MEMORY_SPLIT:-}" ]; then
# set -u # Fail on unset variables
# get_current_memory_split
# echo $CURRENT_MEMSPLIT
# exit 0
#fi
# Everything else needs to be run as root
if [ $(id -u) -ne 0 ]; then
printf "Script must be run as root. Try 'sudo raspi-config'\n"
exit 1
fi
if [ -n "${OPT_MEMORY_SPLIT:-}" ]; then
set -e # Fail when a command errors
set_memory_split "${OPT_MEMORY_SPLIT}"
exit 0
fi
# Interactive use loop
while true; do
FUN=$(whiptail --menu "Raspi-config" 20 80 12 --cancel-button Finish --ok-button Select \
"info" "Information about this tool" \
"expand_rootfs" "Expand root partition to fill SD card" \
"overscan" "Change overscan" \
"configure_keyboard" "Set keyboard layout" \
"change_pass" "Change password for 'pi' user" \
"change_locale" "Set locale" \
"change_timezone" "Set timezone" \
"memory_split" "Change memory split" \
"overclock" "Configure overclocking" \
"ssh" "Enable or disable ssh server" \
"boot_behaviour" "Start desktop on boot?" \
"update" "Try to upgrade raspi-config" \
3>&1 1>&2 2>&3)
RET=$?
do_finish
elif [ $RET -eq 0 ]; then
"do_$FUN" || whiptail --msgbox "There was an error running do_$FUN" 20 60 1
else
exit 1
fi
done
