i am getting this error
[code]Reading package lists... Error!
E: Malformed Description-md5 line; doesn't have the required length (32 != 352) '5150a63a38ef the user-visible functions in R are written in R. It is
possible for the user to interface to procedures written in the
C, C++, or FORTRAN languages for efficiency, and many of R's core
functions do so. The R distribution contains functionality for a
large number of statistical procedures and underlying applied956e286904b0c1ebe5442'
E: The package lists or status file could not be parsed or opened.
[/code]
any help would be great
apt-get update fails
I'm having similar problems on an update too:
- Code: Select all
[ ERR] Reading package lists
W: Architecture: all package 'ibus-gtk' can't be Multi-Arch: same
E: Malformed Description-md5 line; doesn't have the required length (32 != 24) 'e031a824eef3c7a401fe5edc'
E: Problem parsing dependency Depends
E: Error occurred while processing ibus-skk (NewVersion2)
E: Problem with MergeList /var/lib/apt/lists/mirrordirector.raspbian.org_raspbian_dists_wheezy_main_binary-armhf_Packages
E: Couldn't rebuild package cache
sudo apt-get clean
sudo apt-get update
sudo apt-get upgrade
sudo apt-get update
aaa801 wrote:sudo apt-get clean
sudo apt-get update
are you suggesting we add the apt-get?
rinky451 wrote:aaa801 wrote:sudo apt-get clean
sudo apt-get update
What?
