I am using the image 2012-09-18-wheezy-raspbian.
When I try to eject a pendrive connected direct to one of the USB ports I receive this message:
"Error starting job: Failed to execute child process "eject"
Any idea how can I solve this?
[Solved] Failed to execute child process "eject"
I too suffered from this annoyance for quite a while until I discovered the fix.
If you do :-
Et voilá, the problem goes away.
If you do :-
- Code: Select all
sudo apt-get install eject
