Today I got a RPi and wanted to try and run an gameboy emulator http://www.gcat.org.uk/emul/
After using the make command in the terminal, a wild excecutable appeared. Double clicking on it doesn't seem to work, when I go to properties, the "make file executable" checkmark is checked. Simple google searches didnt really help...
I also compiled a simple C++ app using geany, that executable also didn't start.
I'm running the Debian linux, on a 2GB sd card.
What am I missing?
Thanks,
DuckerDuck
Running basic executables?
Why did you try doubleclicking on it?
The web page you linked to states quite clearly how to run it.
So you run it from a terminal. It also says it doesn't work under X Windows - which is the GUI.
- Code: Select all
Put the game ROM file that you want to play in the same directory (e.g. tetris.gb)
Run the emulator (./gameboy tetris.gb). They won't work under X Windows yet
A lot of people can't imagine any other way to "run" something other than "double clicking" on it.
Myself, I can't imagine any other way to "run" something other than running it from the command line.
Two kinds of people in the world...
I must be both kinds then.....
- Moderator
sorry about that, obviously missed that one.
jamesh wrote:I must be both kinds then.....
I'm sure we can make an exception for you JamesH
DuckerDuck wrote:sorry about that, obviously missed that one.
Generally it depends on where the output is going.
If your program uses stdout (and stderr) - for example the Hello World example - you can't just start them using the GUI - what is stdout in a GUI? You have to run a terminal then run the program from the prompt.
I would have thought that the emulator would be using some kind of graphics - so maybe it is writing directly to the framebuffer.
Even for GUI programs, it's much easier (in the early stages of development) to just read a bunch of arguments from the command line, than it is to build a fully-fledged "options/settings" UI
