I am using the headset output and so I try to force the system to use the headphone jack and then set the volume. All I get is the standard "pop" from using the headphone jack and what seems to be a very faint sound from my aplay test. I also tried hello_audio with no success either. I did notice no pop with hello_audio though.
here's a log...
- Code: Select all
root@raspberrypi:~# modprobe snd_bcm2835
root@raspberrypi:~# amixer cset numid=3 1
numid=3,iface=MIXER,name='PCM Playback Route'
; type=INTEGER,access=rw------,values=1,min=0,max=3,step=0
: values=1
root@raspberrypi:~# amixer cset numid=1 60
numid=1,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---RW-,values=1,min=-10240,max=2303,step=0
: values=-153
| dBscale-min=-102.40dB,step=0.01dB,mute=1
No matter the value I set for numid=1 I never get sound. I noticed the mute=1 setting but I havent figure out how to change that value
I'm pretty sure I'm just not understanding the alsa-utils as I've been away from desktop linux for quite some time now but I'm at a loss as to my next steps
Below is the contents of the the amixer if this is needed
- Code: Select all
root@raspberrypi:~# amixer contents
: values=1
numid=2,iface=MIXER,name='PCM Playback Switch'
; type=INTEGER,access=rw------,values=1,min=0,max=1,step=0
: values=0
: values=-153
