VNC Viewer
by Mortimer » Thu Jul 12, 2012 10:03 pm
I tried a couple of VNC viewers (directvnc and xtightvncviewer) but neither worked the way I want. I wanted to see if there was a vnc client that can connect properly to the VNC service in Mac OS X Lion. This is a multi-user aware screen sharing service, and I connect to my Lion machine from my Snow-Leopard machine by opening a URL in the form:
vnc://mortimer:password@192.168.1.1
The trouble I am finding with the clients I have tried so far is that I am not able to specify the user name, only the standard VNC session password.
Does anyone know of a Linux VNC client which would allow me to connect in the appropriate way, that will also run on a Raspberry Pi?
by JeremyF » Thu Jul 12, 2012 10:37 pm
Maybe Remmina? ( sudo apt-get install remmina )
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
by Mortimer » Thu Jul 12, 2012 11:23 pm
I couldn't get Remmina to connect at all. I have also tried Gtkvncviewer, which I could get connect, but the supposed "full screen" mode, wasn't it had scroll bars, frame and controls still visible, yuck!
by JeremyF » Thu Jul 12, 2012 11:44 pm
Very strange. Are you tied in to using built in Mac VNC or can you use a third-party solution like http://sourceforge.net/projects/osxvnc/ ?
by Mortimer » Thu Jul 12, 2012 11:54 pm
Because I want to make use of Lion's multi-user screen sharing, I have to use the built in VNC server of the Lion machine.
by BallisticPain » Thu Aug 23, 2012 8:05 pm
Were you ever able to get this to work the way you wanted?
I use ssvnc. Easily installed if you're using Raspbian image. I do have a 2-3 second lag though. I need to fix that issue.
Thanks!
by Jim JKla » Thu Aug 23, 2012 8:17 pm
There is this noob page on the wiki.
http://elinux.org/RPi_Wheezy_VNC ;)
