Can you change shell font size?
by zedin » Thu Jun 28, 2012 3:24 pm
Is there a way to make the shell font bigger without changing the resolution setting during boot? I have my Pi hooked up to a 720p TV (that for some reason is showing a native resolution at 1080i) and the text is awfully small. I can adjust the resolution in the config.txt file to make text appear larger but I would like to run it at the native resolution but just have a bigger font so I don't have to be right in front on the TV (and can instead lounge in the bed =p)
Is there any command like setting/command that will increase/decrease font sizes so I can say swap back and forth without reboots?
by RaTTuS » Thu Jun 28, 2012 3:31 pm
http://www.mjmwired.net/kernel/Document ... on.txt#126
possibly using
fbcon=font:
on the command line may work
1QC43qbL5FySu2Pi51vGqKqxy3UiJgukSX - Prosliver FTW
by jojopi » Thu Jun 28, 2012 3:53 pm
zedin wrote:Is there any command like setting/command that will increase/decrease font sizes so I can say swap back and forth without reboots?
Assuming you mean the system console font (not in X):
setfont /usr/share/consolefonts/Lat15-Terminus24x12.psf.gz
Also try the other font files in the same directory. You can set the initial font file in /etc/default/console-setup or by "sudo dpkg-reconfigure console-setup".
