How to start without HDMI monitor?
by mabra » Fri Jun 08, 2012 1:05 am
Hi !
I am very disappointed to read, that there is no analog signal.
Is it possible to:
- connect via serial port
- external usb monitor
I just don't understand it and I must see the
boot process. A HDMI/DVI to VGA [my monitor
has two inputs] is just too expensive.
Thanks so far and
best regards,
++mabra
by texy » Fri Jun 08, 2012 6:12 am
That is not strictly true - there is a composite analogue signal output that is automatically enabled if no HMDI monitor/tv is connected - its the yellow
phono connector. Maybe you have a suitable TV to use?
Texy
"!.8inch TFT LCD + Switch Shield" add-on boards for sale here :
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=59&t=40674
50p goes to the Foundation ;-)
Moderator
by bredman » Fri Jun 08, 2012 8:09 am
I recommend that you try a TV with a composite input.
You can also access the RPi over Ethernet by using SSH, see
viewtopic.php?f=26&t=6553&p=93826
by latro666 » Fri Jun 08, 2012 10:57 am
You can get a HDMI to DVI wire for about £2
http://www.amazon.co.uk/s/ref=nb_sb_nos ... vi&x=0&y=0
by mabra » Tue Jun 12, 2012 10:50 pm
Hi !
Thanks for the hints.
There is no TV with this input and no HDMI monitor,
which is enabled.
Does someone know a good HDMI to VGA CONVERTER
[I know, this cannot be done by wiring] or does someone
probably has a recommendation of a usb connectable
display adapter??
Thanks!
br++mabra
by JeremyF » Tue Jun 12, 2012 10:59 pm
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
by mahjongg » Tue Jun 12, 2012 11:28 pm
A second hand DVI-D monitor will probably be cheaper, and give a better overall result.
Serial input (either the onboard UART, or a USB RS232 interface) enables remote login, so you can run headless, and any old TV with composite input will also enable you to login.
Moderator
by liz » Tue Jun 12, 2012 11:39 pm
mabra wrote:Hi !
which is enabled.
Any old CRT (cathode ray) TV should do - do you have access to one of those?
by mabra » Sat Jun 16, 2012 11:40 am
Hi !
Thanks ALL !
"latro666" drive me into the right direction.
best regards,
++mabra
by complete_beginner » Sun Jun 17, 2012 9:59 am
Sorry if i'm exhausting this point guys but i'm a complete noob as the name suggests. So if i get either a cable or adapter that goes from HDMI to VGA then i can use an old monitor ???
Cheers,
by Kris » Sun Jun 17, 2012 8:57 pm
What do you intend to do with your Pi?
Converting HDMI to VGA isn't as simple as you would think, and so adapters are expensive.
A better option would be either
-Borrow an HDMI or Component TV/Monitor
-Go to a friends house who has one of the above
And then install VNC so you can remotely connect to your Pi from your existing PC.
Otherwise you might as well buy a cheap DVI/HDMI capable monitor for about £60.
by JeremyF » Mon Jun 18, 2012 12:52 pm
Kris wrote:What do you intend to do with your Pi?
http://elinux.org/RPi_VerifiedPeriphera ... y_adapters -- HDMI-VGA for cheaper than you would expect.
by alexeames » Mon Jun 18, 2012 5:53 pm
JeremyF wrote:http://elinux.org/RPi_VerifiedPeriphera ... y_adapters -- HDMI-VGA for cheaper than you would expect.
But be aware that some of them do not handle sound (if that is an issue for you - it wasn't an issue for me).
My Pi uses 2 watts - what what? ---- HiRes early production Pi photos RS Front Back | Farnell Front Back
by complete_beginner » Sat Jun 23, 2012 12:08 pm
Thanks guys,
Sound isn't really an issue. I can always use the 3.5 port and use headphones. I just want to use an old monitor i purchased for $25. It uses VGA only. So i am going to try and find an HDMI/VGA adapter plug and attach the pi to the monitor. Hopefully it works :-)
by Matt_ » Sat Jun 23, 2012 5:09 pm
Use the yellow socket, I think its called Composite. Still gives a good quality image, once you have it set up, run SSH. Then you don't need a monitor, or keyboard or mouse even :D
by Drulli » Sun Jun 24, 2012 12:03 pm
as far as I know, SSH is running already with the standard debian squeeze image.
That means you don't need a monitor at all (provided your Pi gets its IP address via DHCP -- and almost all routers will provide DHCP).
If you're running windows, download "Putty", insert the Pi's IP, login with pi/raspberry and you're done. Just keep in mind that booting up will take the Pi some minutes.
by penguintutor » Mon Jun 25, 2012 7:08 am
HDMI to VGA is much easier than people think.
It does need a converter to go from digital to analogue, but these can be built into a cable and fairly inexpensive. The one I am using cost £15
http://www.penguintutor.com/blog/viewbl ... g=6354#vga
by complete_beginner » Mon Jun 25, 2012 10:32 am
I've just been down to the electronics shop and theres a Digitech active vga + audio to HDMI converter for $90. An alternative is a vga/HDMI adapter which could work out a bit cheaper. Think the adapters cost about $60.
by RaTTuS » Mon Jun 25, 2012 10:37 am
1QC43qbL5FySu2Pi51vGqKqxy3UiJgukSX - Prosliver FTW
by penguintutor » Mon Jun 25, 2012 1:57 pm
If you are in the US then you could try the following from Amazon: http://amzn.to/Q2vXBM
I can't confirm it definitely works, but it looks and sounds the same as mine which does work (although a different colour cable). Costs about $20.
by JeremyF » Mon Jun 25, 2012 2:30 pm
Identical converters are down to $16 on eBay. (Links can be found in my signature...)
by tawalker » Mon Jun 25, 2012 3:04 pm
I'm surprised more folk haven't suggested this, but another possibility for those seeking a (relatively) cheap, and HD-capable, HDMI display, is a small flat-screen TV.
I've looked around plenty of places at cheap monitors, and I don't think I've seen any with HDMI ports until the price gets into the £100-150 bracket. Beneath that level, you'll be lucky if you find a DVI port on them, and the cheapest only sport a VGA socket. Even if you find a lower-cost DVI monitor, they don't always handle sound.
On the other hand, visit almost any big supermarket (Asda, Tesco, etc.) or electronics store, and you can usually find a 16" or 18" flat-screen TV for as little as £65-70. The quality may not be top-notch (though most that I've seen working don't look too bad), and "label-snobs" might bristle at the typical "A.N.Othercom" badge on the front, but these TVs usually give you at least one HDMI port, and often an extra £20 or so will get you a DVD player built-in.
I don't have one of these TVs myself, but only as my disposable income isn't even that disposable most of the time :oops: All the same, it seems to me like another option to consider for Pi-folk seeking a cheap HD display.
Raspberry Pi Model B ("ryo-ohki") - Arch Linux/ARM (hard float)
Visit Eee 701 Planetoid (http://eee701planetoid.wordpress.com/) for continuing adventures with an Eee 701SD and Raspberry Pi...
by MotoBlue » Mon Jun 25, 2012 4:35 pm
tawalker wrote:I've looked around plenty of places at cheap monitors, and I don't think I've seen any with HDMI ports until the price gets into the £100-150 bracket. Beneath that level, you'll be lucky if you find a DVI port on them, and the cheapest only sport a VGA socket. Even if you find a lower-cost DVI monitor, they don't always handle sound.
viewtopic.php?f=60&t=8931 £10 for a monitor with DVI-D input, internal powered usb-hub and powered speakers, keyboard and a mouse.
by Jim JKla » Mon Jun 25, 2012 8:11 pm
I got a proline tv with a blown PSU getting thrown out got a PSU for 30 quid That got me a monitor with an hdmi port the default font was tiny but I'm running wheezy I edited
/etc/default/console_setup
FONTFACE="Terminus"
FONTSIZE="32x16"
Note include speechmarks and rebooted
and the command line font and the raspi-config become eminately readable I had to enable overscan to stop it loosing the start of the line.
However composite makes for incomplete lines where the text vanishes off the right of the screen.
Once started and you have completed your doings with the raspi-config menu one of the last lines on boot gives you the IP it's picked up from DHCP and you can use that with putty ro get a remote login with a laptop/notebook/PC
In fact if you know how to read your router you can get that IP address from there and login with putty and run raspi-config from there.
We have a thread running on starting blind using only putty and a remote login Ok it wont play the startx without a monitor but you can build a LAMP webserver provided you run apt-get update.
The MySQL goes all non install if you have not run the update. The result is a little beast that will run PHP ok your not going to have the Wikipedia on there but it will allow you to play with some basic stuff.
