I have recently found the plug in charger for my LG Phone which has a USB port at the bottom and I have a Micro USB cable lying around somewhere but before I go looking for it what it want to know is; will it work? The specs I found on the label are below:
OUTPUT: 5.1V --- 0.7A
The line at the bottom should be above --- but that was the nearest I could get using this editor.
LG Power Supply? Will it work?
Those are within spec for the RPi but the proof of the pudding will be in it's use.
