where to buy a micro usb power supply & choosing a sd card
by Blast » Sat Sep 15, 2012 4:13 am
the only two things I need to purchase before I can start using my raspberry pi is a micro usb power supply and I need help choosing an sd card
I looked on newegg.ca for a micro usb power supply but did not find any, I need one that meets the requirements for the rpi (at least 700mA at 5V)
I also need help picking the right sd card that would work well for the rpi
by itimpi » Sat Sep 15, 2012 4:48 am
You should find that power supplies for common devices such as Kindles or most tablets will do the job. You will also find that iPhone/iPad chargers can be used in conjunction with a USB->micro USB cable that supports charging.
by MyDogWinston » Sat Sep 15, 2012 12:09 pm
Blast,
Are you in the US?
I bought what I needed from MCM Electronics.
http://www.mcmelectronics.com/content/e ... MgodZmQAvw
They ship fast, their prices seem reasonable, and all the components I received work fine. I got the 4GB PNY card.
MDW
by Blast » Sat Sep 15, 2012 9:37 pm
itimpi wrote:You should find that power supplies for common devices such as Kindles or most tablets will do the job. You will also find that iPhone/iPad chargers can be used in conjunction with a USB->micro USB cable that supports charging.
I don't have a Kindle or tablet, I do have a iPhone/iPod USB Power Adapter but it says 100-240v so I don't know if that is enough power.
MyDogWinston wrote:Blast,
Are you in the US?
MDW
Unfortunately, I live in Canada.
by frkhrd » Sun Sep 16, 2012 8:13 am
I found a nice one in camera area of large discount store walxx.. that had 3 interchangeable usb port ends. The nice part is the interchangeable end makes for a simple power disconnect adapter---------------> >---pi plug unplug
Name on item was Onn output .8 amp 5v input 100 to 240 v. cord is about 4.9 foot and the ends are 6"
by itimpi » Sun Sep 16, 2012 8:38 am
Blast wrote:
itimpi wrote:I don't have a Kindle or tablet, I do have a iPhone/iPod USB Power Adapter but it says 100-240v so I don't know if that is enough power.
That should work fine (I use one myself). It is the output side that matters and if you look closely that one is rated at 5V 1A. All you need is a USB to Micro USB cable which you can easily get from somewhere like Amazon. You want a reasonable quality cable that is not too long to kep it's resistance (and thus the voltage dop over it) down.
by sukhoi » Thu Dec 06, 2012 6:11 pm
I have a Sony Ericsson charger. The output is 5v and 850 mA. Will this work with the new rpi model b??
by efflandt » Fri Dec 07, 2012 12:30 am
sukhoi that should work, they recommend at least 700 mA (500 mA for the Pi and 100 mA each for keyboard and mouse on USB).
I ordered the Newark 5.25 V 1 A psu at the same time I ordered my new model B (through element14/newark) and the RPi overclocked at 930 MHz still has 4.99 V at T1/T2 with 100 mA BT mini-receiver (keyboard/mousepad) and 500 mA mini USB WiFi adapter connected directly to it (I am posting this from the Pi playing internet music).
by Jonen » Mon Dec 17, 2012 7:42 pm
will 4,8Volts suffice with 1.0mA? will the low voltage physically hurt the unit?
by pi-r-squared » Tue Dec 18, 2012 4:44 pm
In the US, try a Goodwill Store with a computer section. I visited one last week and they had a basket of old 5V cell phone charges that could work if they have a micro-USB connector. Flea markets could be good also with people getting rid of junk.
by RaTTuS » Tue Dec 18, 2012 4:50 pm
Jonen wrote:will 4,8Volts suffice with 1.0mA? will the low voltage physically hurt the unit?
low voltage wont hurt it it will just not work or not work enough to be stable [well it may cause SD card corruption]
1QC43qbL5FySu2Pi51vGqKqxy3UiJgukSX - Prosliver FTW
by onebeatconsumer » Tue Feb 12, 2013 8:40 pm
efflandt wrote:sukhoi that should work, they recommend at least 700 mA (500 mA for the Pi and 100 mA each for keyboard and mouse on USB).
@efflandt -my iPhone 5v 1A little guy is doing just fine for now. I've got it cranked up about where you do, but my HP Studio II storage box is self-powered, so I'm probably not drawing squat right now. The question I had is how are you posting to this forum from the PI? What are you using? I ask because all I've been using is Raspbmc and I don't see any browser add-ons for it. ty
by fjib » Fri Mar 08, 2013 8:04 pm
Does my Sony Ericsson GreenHeart Charger(it was included in the Xperia PLAY-docking(if that helps))it has an output of 550mA, is this enough for the Pi to work fine???
by supra » Sat Mar 09, 2013 10:58 am
fjib wrote:Does my Sony Ericsson GreenHeart Charger(it was included in the Xperia PLAY-docking(if that helps))it has an output of 550mA, is this enough for the Pi to work fine???
Absolutely. That will do.
Supra
by Cloudcentric » Sat Mar 09, 2013 11:03 am
It is recommended to use 5V 0.75A minimum http://elinux.org/RPi_VerifiedPeriphera ... r_adapters
I know everything about nothing"
by fjib » Sun Mar 10, 2013 7:38 pm
Nevermind, bought a starterkit from MPX, there was everything I needed to use the Raspberry Pi :-)
by Guysilat » Wed May 08, 2013 1:10 pm
In AU I found them really cheap at [url]qavo.com.au[/url] :ugeek:
