VNC Server to Boot on Logged In User
by D.E.L.B. » Sat Jul 07, 2012 12:32 pm
There is a script that makes the script start on boot, but when I connect to the Pi from my PC it connects to the "root' desktop instead, what I want it to do is the script to boot up when I login to my username which are my initals "jjones."
So how can I do this? The script is this:
### BEGIN INIT INFO
# Provides:          vncboot
# Required-Start:    $remote_fs $syslog
# Required-Stop:     $remote_fs $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Start VNC Server at boot time
# Description:       Start VNC Server at boot time.
### END INIT INFO
#! /bin/sh
# /etc/init.d/vncboot
USER=root
HOME=/root
export USER HOME
case "$1" in
 start)
   echo "Starting VNC Server"
   #Insert your favoured settings for a VNC session
   /usr/bin/vncserver :1 -geometry 1280x800 -depth 16 -pixelformat rgb565
 stop)
   echo "Stopping VNC Server"
   /usr/bin/vncserver -kill :1
   echo "Usage: /etc/init.d/vncboot {start|stop}"
   exit 1
esac
exit 0
The tutorial is here:
http://elinux.org/RPi_VNC_Server
by D.E.L.B. » Sat Jul 07, 2012 3:47 pm
I searched high and low on Google to get this to work, and I'll show you how I got it to work.
Instead of using the script in the Rasberry Pi wiki, use this one provided by "Penguin Tutors":
#!/bin/sh
# /etc/init.d/tightvncserver
# Customised by Stewart Watkiss
http://www.penguintutor.com/linux/tightvnc
# Set the VNCUSER variable to the name of the user to start tightvncserver under
VNCUSER='*YOURUSERNAMEHERE*'
case "$1" in
  start)
    su $VNCUSER -c '/usr/bin/tightvncserver :1'
    echo "Starting TightVNC server for $VNCUSER "
  stop)
    pkill Xtightvnc
    echo "Tightvncserver stopped"
    echo "Usage: /etc/init.d/tightvncserver {start|stop}"
    exit 1
esac
exit 0
Now, change the VNCUSER=pi to VNCUSER=*YOUR USERNAME HERE*.
That'll make it boot on the username of which you want it to boot on... but I then received the grey screen error when remotely accessing the Pi from my computer, now the way you fix this is, open up the xstartup file that was created when VNCSERVER executes on your desired username. Now the way you access it and edit it is by:
sudo nano .vnc/xstartup. .vnc is usually in the home directory.
Delete everything that is in xstartup (or not in as mine was), and add this:
#!/bin/sh
xrdb $HOME/.Xresources
xsetroot -solid black
lxterminal &
/usr/bin/lxsession -s LXDE &
Now it should work.
by geezbeez » Sat Jul 07, 2012 3:51 pm
your starting vncserver under root on startup for user root in home dir /root so that's what will happen.
You want vncserver running under jjones
You can have vncserver running under various users you just set them as :0 :1 :2
After you have started vncserver once under jjones you should have a .vnc dir in your home dir (if I remember correctly)
You can try using your script,
Edit and change USER=root and /root to your user and your home dir
Make sure you use the desired number :1 :2 :3 you want for your user. So you might want to change :1 to :2
and #!/bin/sh The convention is that this is first line of script not after other comments.
Could just have something like this in your startup instead of a script?
su -c "/usr/bin/vncserver :2 -geometry 1280x800 -depth 16 -pixelformat rgb565" - jjones
by D.E.L.B. » Sat Jul 07, 2012 3:53 pm
geezbeez wrote:your starting vncserver under root on startup for user root in home dir /root so that's what will happen.
I tried all of these but none of them worked, the script provided on the Pi wiki is not efficient enough to do what I wanted it to do. :). The post I made below the OP now works.
I appreciate the input though!
by D.E.L.B. » Sat Jul 07, 2012 5:46 pm
I'd edit my post but I also ran into another problem, this one:
viewtopic.php?f=28&t=8462&p=101282
If you receive this error, look at the commands:
sudo chmod 1777 /tmp/.X11-unix
sudo chown root:roo /tmp/.X11-unix
Add them in here, with the "Penguin Tutors" script, I've done this one for you:
#!/bin/sh
case "$1" in
  start)
    sudo chown root:root /tmp/.X11-unix
  stop)
    pkill Xtightvnc
    exit 1
esac
exit 0
Done.
by geezbeez » Sat Jul 07, 2012 11:28 pm
Yes this script is much better.
I didn't really see much point in starting a VNC server on boot.
But then I found there's a free android vnc viewer app which opens up a lot of possibilities.
by bmwhite » Sun Jul 08, 2012 7:20 pm
Very much a beginner here but I got this to work just following the steps on the penguin tutor website. Note I think there is one error with the startup script that creates the script vncserver - Line 4 where he lists his web address.
#!/bin/sh
<clip>
Should there be a # in front of that to make it a comment? When I run his start stop commands:
sudo /etc/init.d/tightvncserver start
sudo /etc/init.d/tightvncserver stop
Line 4 seems to throw an error. When I comment it out, I get clean service start and service stop messages.
by dktucson » Sun Jul 08, 2012 10:02 pm
The beauty of starting a VNC server at boot is so the pi can be run in "headless" mode with no monitor, keyboard or mouse physically attached to it. If you get wireless to work now all you have is the 5v power connector--no more "spaghetti pi" of wires going everywhere . The pi is more stable with fewer peripherals attached... I have mine setup headless with a vnc server at boot and a tp-link wrg-322 wireless fob
by D.E.L.B. » Sun Jul 08, 2012 10:05 pm
bmwhite wrote:Very much a beginner here but I got this to work just following the steps on the penguin tutor website. Note I think there is one error with the startup script that creates the script vncserver - Line 4 where he lists his web address.
#!/bin/sh
<clip>
Yes, add a comment. As in add a #.
by D.E.L.B. » Sun Jul 08, 2012 11:05 pm
Only just noticed, if you don't want lxterminal to boot when connecting to the Raspberry Pi desktop on launch, remove the "lxterminal &" from:
#!/bin/sh
lxterminal &
by sco` » Mon Jul 09, 2012 8:52 pm
I have always done things slightly different with my other *nix machines (still new and self taught)
but i'm unable to do a "pre-login" x11vnc server session. I think this is because there is no logon manager e.g lightdm ???
I have used ssh tunnels to start the vnc server when I wanted to connect (read that its better for security to start the server when you want it, not from boot) with this type of command....
ssh -p xxxx-t -L 5900:localhost:5900 user@RaspberryPI "x11vnc -localhost -display :0" -auth /var/lib/gdm/:0.Xauth
with the raspi i had to ssh in first and run "ps wwwwaux | grep auth" which pulled up
-auth /tmp/serverauth.qQALchRhXl
then to view -
vncviewer -encodings "copyrect tight zrle hextile" localhost:0
BUT like I said, without a login manager I cannot do this pre-login as i would with
ssh -p xxxx -t -L 5900:localhost:5900 admin-user@192.168.1.XX SUDO x11vnc -safer -localhost "-auth /var/run/lightdm/root/:0 -display :0"
is it possible to tunnel in with ssh pre login without a login manager?
by largeduck » Thu Jul 19, 2012 3:46 pm
geezbeez wrote:Yes this script is much better.
Thanks for the inspiration.....
http://www.youtube.com/watch?v=wqTAC2He9e8
by Allen » Fri Jul 20, 2012 11:51 am
change the vncboot as listed in the wiki (http://elinux.org/RPi_VNC_Server) to
### BEGIN INIT INFO
# Provides:          vncboot
### END INIT INFO
#! /bin/sh
USER=pi
HOME=/home/pi
export USER HOME
case "$1" in
 start)
   su - $USER -c '/usr/bin/vncserver :1 -geometry 1680x1050 -depth 16 -pixelformat rgb565'
 stop)
   exit 1
esac
exit 0
that should get you a suitable VNC session at boot without having to delete other things and you can add whatever user you like (change USER and HOME as appropriate and of course make sure you have started the server by hand and set the password for the required user first).
Change the option for server to your own prefs of course.
