After a few boot up problems my Pi is now usable but I don't seem to be able to alter screen resolution.
I have booted using composit and hdmi, the former is a bit big and the latter is too small, when I go in to monitor settings I only seem tho get the choice of auto and one specific setting.
Any advice re screen options appreciated.
Geffers
Resolution Settings
http://elinux.org/RPi_config.txt
http://elinux.org/R-Pi_ConfigurationFile
I don't recommend using composite video if you have access to an HDMI display, and it sounds like you do.
Anyway, I'm going to assume that HDMI display is a 1080p 60Hz TV for my example code, and that you want to make the pixels larger by sending video at the resolution of 720p 60Hz. Once again, just an example.
- Code: Select all
disable_overscan=1
hdmi_mode=4
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
JeremyF wrote:http://elinux.org/RPi_config.txt
- Code: Select all
disable_overscan=1
hdmi_mode=4
Thanks, that has helped, I'll explore the config file a bit more.
Strange though, despite entering your suggested settings when the display started it showed as 1184x624 but the screen display was much better than previous.
Geffers
- Code: Select all
disable_overscan=1
hdmi_mode=4
The composite lead is just more convenient, the HDMI lead is so thick the board then doesn't lay flat.
Re your suggestion, I have a Sony Bravia, the manual states 1920x1080, not sure if it is i or p or cannot see in the manual if it is 60Hz or 50Hz.
Geffers
