I need to try and narrow down if this is a board problem or some other setup problem.
On boot I get a continuous error;
mmc0: Error 110 whilst initialising SD card and Problem reading SD status register.
After a period of time, up to 5 minutes it boots.
HDPARM -t shows 1.16MB/sec which is ridiculously slow (10.43MB/sec) on my HP laptop.
A Sandisk Extreme Class 10 will not boot at all continuously giving error;
mmc0: timeout waiting for hardware interrupt.
Using a 1AMP PSU.
Geffers
Boot Errors
Sounds like an SD card issue to me. Are you using the debian wheezy beta? It works with a wider selection of SD cards than the Squeeze version.
Read the wiki first, all your topics are discussed there, and in other forumtopics, like this one:
http://www.raspberrypi.org/phpBB3/viewtopic.php?p=113423#p113423
mahjongg wrote:Read the wiki first, all your topics are discussed there, and in other forumtopics, like this one:
Thanks Mahjongg, that sorted my unbranded (Supposedly Toshiba) SD card but strangely not my Sandisk Extreme.
Tried Wheezy on the Sandisk but I get nothing after the Raspberry image comes up on the screen.
Geffers
Perhaps the "SanDisk extreme" is a cheap chinese copy, a "fake". Its especially the SanDisk Extreme brand that is copied, and a large part of SanDisk Extremes you buy on ebay are fakes!
Just google for "SanDisk fake" and you will see what I mean.
The biggest problem (except very low quality and speed) is that "2 GB" fake cards often actually are only capable of storing 1 GB.
mahjongg wrote:Perhaps the "SanDisk extreme" is a cheap chinese copy, a "fake". Its especially the SanDisk Extreme brand that is copied, and a large part of SanDisk Extremes you buy on ebay are fakes!
I think I am OK with the sandisk, bought from a reputable outlet (Not ebay) and it shows as 16GB.
Geffers
There is a recent discovered issue with pullups not enabled on some of the SD-card control and data lines, which can be solved in software, but might not yet have been in the software you have been using.
mahjongg wrote:There is a recent discovered issue with pullups not enabled on some of the SD-card control and data lines, which can be solved in software, but might not yet have been in the software you have been using.
Yes download bootcode.bin from here:
https://github.com/raspberrypi/firmware ... aster/boot
and replace the one on your sdcard.
- Moderator
dom wrote:mahjongg wrote:There is a recent discovered issue with pullups not enabled on some of the SD-card control and data lines, which can be solved in software, but might not yet have been in the software you have been using.
OK, done that, will check it out tomorrow.
Thanks,
Geffers
regretfully that didn't work, same error message
Geffers
