hi
iam running xbmc on raspberry know someone if you can hookup hdd with 2000gig and with power supply? on the raspberry
gr egbert
hdd with xbmc
I've done it with OpenElec XBMC and a 500 gig USB HDD (externally powered) and it worked fine (auto detected).
hello
oke iam going to try it with a beter power suply i got now 700ma
gr egbert
gr egbert
Are you saying you are not using a separate power supply for your external hard drive? It needs its own power supply. No way will it run with power from the USB port (unless you are using a powered hub).
no for the raspberry i need beter power suply
egbert1987 wrote:no for the raspberry i need beter power suply
OK. Good
