Screensaver?
Does Raspberry Pi have a screensaver? I just noticed on my plasma TV, I see faded outline of Raspberry wallpaper even after I turn off the Pi. I heard it's bad to to leave static image on plasma TV, that it could just imprint there.
- Code: Select all
sudo apt-get install xscreensaver
You'll then have a new entry in Preferences called screensaver
I got this:
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main libio-socket-ssl-perl all 1.76-1
404 Not Found
Failed to fetch http://mirrordirector.raspbian.org/rasp ... -1_all.deb 404 Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing
404 Not Found
sudo apt-get update && sudo apt-get upgrade -y
then try again
then try again
1QC43qbL5FySu2Pi51vGqKqxy3UiJgukSX - Prosliver FTW
