SD Cards?
by lsbx22 » Tue Nov 06, 2012 5:54 pm
Hi, which SD cards are compatible with the raspberry pi model B 512MB?
I can get a normal 4gb SD cardi model b
I could also get a Micro SD card (with an adapter to make it normal sized) up to 32GB
or a SDHD card up to 32GB
which ones are compatible with the Raspberry pi model b 512mb?
thank you for your responses
by itimpi » Tue Nov 06, 2012 6:04 pm
In theory any card of up to 32GB if as it is a SDHC card of class 10 or less should be compatible.
However the Pi can sometimes be picky in no obvious pattern so it can be a case of try the card. Having said that I have about 20+ SD cards in a variety of sizes, class and manufacturer and they all work fine for me.
by lsbx22 » Tue Nov 06, 2012 6:15 pm
so SDHC should be ok?
by omiez » Wed Nov 07, 2012 12:26 am
http://elinux.org/RPi_VerifiedPeripherals
In this site you can see a list of tested hardware and see what is working and what´s not.
Have a look.
SDHC is fine i use 3 cards 4GB Sandisk Class4,8Gb Sandisk Class 4 this one micro sdhc with adapter and my last is a Sandisk 32Gb Class 10 45mb/s model.
All working fine with Raspbian,Raspbmc and Openelec.
Nr.1 Raspberry Pi Mod.B Rev.2 256Mb Ram (Raspbian)
Raspberry Pi Mod.B Rev.2 512Mb Ram (Maybe i´ll get one)
by pluggy » Wed Nov 07, 2012 11:54 am
It isn't as picky with an up to date image as it once was. Sandisk Class 4 and Samsung Class 6 all work for me. High speed ones (class 10) probably won't make much difference with what the Pi does.
