Hello folks,
New user here. This question may be somewhat off-topic, but I failed to find out a better forum to post it. Also, I could not find another topic about this (but I think it already exists).
What is the normal/acceptable voltage variation for a good switching mode power supply under a given load? I'm using a Kindle 3 charger as power supply for my RPi and, before trying to switch to a Chinese no-brand 1A source, I though it was a good idea to check the voltage output in a workbench. All measures were taken with a simple multimeter, I have no oscilloscope to check for the ripple and other AC noise.
A Kindle charger (rated 5V, 850mA max) with no load measured 4,9V. When powering some resistors and LEDs totaling a load of 85mA, output voltage dropped to 4,84V.
One no-brand supply (rated 5V, 1A) gave 5,14V with no load and 4,94V under 85mA. Another one (rated 5,2V 1,5A) gave 5,5V with no load and 4,87V with 85mA.
I will continue to use the Kindle charger for my RPi but I', really curious about the reliability of such products. What is the normally accepted variation for these off-the-shelf power sources?
Suitable voltage variation for switching mode power supplies
You need to check the voltage from TP1 to TP2 on the Pi while running under full load to know if your power supply is acceptable, ideally you want 4.85+ volts.
