Midori - Logging out from forum
by raspb » Sat Aug 18, 2012 4:50 pm
I am posting on forum glitches section because I cannot see the Raspberry PI forum's log out link on Midori browser included in Raspbian?
by abishur » Mon Aug 20, 2012 3:27 pm
Are you using the default theme or prosilver?
Dear forum: Play nice ;-)
Moderator
by raspb » Wed Aug 22, 2012 9:09 am
abishur wrote:Are you using the default theme or prosilver?
Only using what came with the software.
by abishur » Wed Aug 22, 2012 12:07 pm
I meant on the forums ;-) The forum has two separate styles the default Red/white based theme and a blue/white one called Pro Silver
Moderator
by raspb » Thu Aug 23, 2012 8:00 am
I cannot say which theme, perhaps you could post pictures.
Have some further details about the problem - when the forum is at full size on the TV screen, then this is invisible:
"FAQ Logout [ raspb ] raspb
Unread Posts New Posts"
If I reduce the forum screen from the browser's 1-click feature, then it becomes visible.
by abishur » Thu Aug 23, 2012 11:35 am
Oh, so the issue is that your screen resolution doesn't fit on your screen.
Try editing /boot/config.txt and adding
disable_overscan = 1
It might just be that overscan is putting things just outside the range of your screen. Otherwise take a look at this link and manually setting the resolution to something your TV can handle :-)
Moderator
