MicroSD on future boards?
Suggestions and requests for the Raspberry Pi Foundation
by edent » Sun Jun 24, 2012 12:01 pm
Perhaps it's just me, but I had real difficulty finding a full sized SD card. I have loads of microSD cards - because that's what most phones take.
In the end, I used an SD adapter - which juts out of the board quite far.
So, my suggestion would be to use a micro SD port rather than the full version in future revisions.
  • Mechanically identical, so hopefully not too hard to rejig the layout.
  • Smaller, so would be harder to knock and break.
  • More common. Almost every phone uses these memory cards - so people should have an old one laying around. (Same rationale as using microUSB for charging)
Just a thought :-)
by nick.mccloud » Sun Jun 24, 2012 12:21 pm
The vast majority of the web shops I see are selling SDHC cards offer many many standard sized ones and only a few micro cards - and yes, they knew that they would stick out of the side of the Pi.
A respin of the board is very unlikely in the next year or so. Consider also that manual dexterity is not a forte of many young people (as their brains are still developing until about 15/16) and the bigger sized card is more suitable.
by JeremyF » Sun Jun 24, 2012 12:27 pm
Also you can always put micro and mini SDs in an adapter. You can't really make a full-size SD smaller it's "too late"
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
by AndrewS » Sun Jun 24, 2012 2:10 pm
MicroSD cards are also much easier to lose ;)
by jamesh » Sun Jun 24, 2012 3:05 pm
I believe uSD cards are not rated to a high enough number of insertions and are mechanically less robust, in addition to the comments above.
Moderator
