According to the hardware entry in the wiki http://elinux.org/RPi_Hardware (under the components section) there is a DSP on the BCM2835 SOC. It would be fantastic if Broadcom would make available the docs for this DSP. As a professional DSP programmer, I would love to see what its capabilities are, and I would guess that there are a bunch of interesting projects that could come from the community. My son and I have been having a lot of fun with our PI, and have a few audio projects in mind that would benefit greatly from a DSP.
If there is enough interest from the community, is there a chance that Broadcom would make these docs publicly available?
Request for DSP documentation
We're working on it. That's all I can say at the moment.
Interesting... I hadn't noticed that the chip has a DSP in it until you pointed it out. Now I'm getting flashbacks to college, noise reduction projects, z-domain filtering, etc. etc...
I wonder if something like ALSA could take advantage of that?
The GPU actually has quite a few cores in it for various things - Vector/scaler core for general compute, various 'Quad' processors for 3D work (nasty things to program), plus many HW blocks for differing functions (Camera ISP, video Encode/decode etc). At the moment, no docs for the GPU are publicly available.
- Moderator
andyroyal wrote:I wonder if something like ALSA could take advantage of that?
It does a little. The ALSA driver advertises it can handle all sample rates. HDMI may only handle 48kHz. The GPU will handle the resampling.
- Moderator
Is that typo, where you should have said "scalar", or does the core contain processing units specifically designed to do scaling?jamesh wrote:Vector/scaler core for general compute
I used to be in the old video encode/decode/output processing game meself y'know. I'd guess there's some kind of embedded microcontroller in there to control the cores, and if we were able to program that up...
I'm now a filesystem bloke - I mentioned the DSP core on the Raspberry Pi to a few colleagues over lunch and immediately they had a few ideas about what you could do with it. For example SHA-256 brings a CPU to its knees but a DSP could do a great job there.
I'm liking the Raspberry Pi ever more by the minute.
[/quote]andyroyal wrote:Is that typo, where you should have said "scalar", or does the core contain processing units specifically designed to do scaling?jamesh wrote:Vector/scaler core for general compute
A scalar is a singular quantity, i.e. a tensor with dimension (or rank) 0.
GPU could do DSP, but I've yet to find out how to render to an off screen frame buffer. And have the result returned as an array of any dimension.
Cheers Jacko
Pi=B256R0USB CL4SD8GB Raspbian Stock. 13D https://dl.dropbox.com/u/1615413/Own%20Work/Dimensions.pdf ... Looking for an interesting project to hold my attention.
Both
There are two powerful RISC processors and one vector processor. As well as all the other stuff James mentioned. We differentiate between the two with "scalar" being the normal processors, and "vector" being the vector processor. And "James" for James.
Neil
I'm working on an idea for OpenDSP, such that the particular architecture of the DSP used does not have to be known. Working as like a VM for DSP, with possible JIT target compilers.
https://github.com/jackokring/jarvar/wiki/DSP
Here's a software simulation of a DSP thread, which maintains relative synchronization between DSP units. You can use this freely to build large DSP simulations, and try out some parallel DSP. Just in Java at present, as I'm busy looking at the FX docs and such.
https://github.com/jackokring/jarvar/blob/master/jarvar-base/src/uk/co/peopleandroid/jarvar/internals/SoftDSP.java
+1 I'd love to use the RasPi for audio effects, with a usb audio input.
Cheers!
Cheers!
Does this mean we could make a DAB or DRM radio out of the Pi?
