I've been working on getting a live server working on my Raspi and have been using this page that I have found.
http://www.lowendbox.com/blog/.....ink-1-vps/
It was written long before the rise of the Pi so is for guidance only, but so far has been very good at helping me get this up and running.
General guidance on setting up web server / php / mysql [LINK]
nginx and php5-fpm are a nice combo for this. It is often used in production by people I know.
I threw this together to show how to do a quick and nasty php and sql for education purposed or quick hacks. You would never do this in production. I have cut some corners to keep things brief.
You will need to wait until the Foundation is supplying Debian Wheezy for your Pi or build PHP5.4 yourself to get the builtin web server.
Here are some quick notes on setting up MySQL, nginx and PHP on the R-Pi.
This assumes you are at a command prompt logged in as root.
make a note of the IP address
when prompted enter the root password
here is an example config file to get you started..
change the line that sets listen...
to:
to test use a browser and go to http://[that IP you made a note of at the beginning]/test.php
- Code: Select all
>ifconfig
- Code: Select all
>aptitude install mysql-server mysql-client
- Code: Select all
>aptitude install nginx
- Code: Select all
>aptitude install php5-cgi php5-mysql php5-curl php5-gd php5-idn php-pear php5-imagick php5-imap php5-mcrypt php5-memcache php5-mhash php5-ming php5-pspell php5-recode php5-snmp php5-sqlite php5-tidy php5-xmlrpc php5-xsl
- Code: Select all
>vi /etc/nginx/sites-available/default
- Code: Select all
server {
listen 80; ## listen for ipv4
server_name localhost;
access_log /var/log/nginx/localhost.access.log;
location / {
root /var/www;
index index.php index.html index.htm;
## Images and static content is treated different
location ~* ^.+.(jpg|jpeg|gif|css|png|js|ico|xml)$ {
access_log off;
expires 30d;
root /var/www;
## Parse all .php file in the /var/www directory
location ~ .php$ {
fastcgi_split_path_info ^(.+\.php)(.*)$;
fastcgi_pass backend;
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME /var/www$fastcgi_script_name;
include fastcgi_params;
fastcgi_param QUERY_STRING $query_string;
fastcgi_param REQUEST_METHOD $request_method;
fastcgi_param CONTENT_TYPE $content_type;
fastcgi_param CONTENT_LENGTH $content_length;
fastcgi_intercept_errors on;
fastcgi_ignore_client_abort off;
fastcgi_connect_timeout 60;
fastcgi_send_timeout 180;
fastcgi_read_timeout 180;
fastcgi_buffer_size 128k;
fastcgi_buffers 4 256k;
fastcgi_busy_buffers_size 256k;
fastcgi_temp_file_write_size 256k;
## Disable viewing .htaccess & .htpassword
location ~ /\.ht {
deny all;
upstream backend {
server 127.0.0.1:9000;
- Code: Select all
>echo "deb http://ftp.uk.debian.org/debian wheezy main" >> /etc/apt/sources.list
- Code: Select all
>apt-get update
- Code: Select all
>apt-get install php5-cli php5-common php5-suhosin
- Code: Select all
>apt-get install php5-fpm php5-cgi
- Code: Select all
>vi /etc/php5/fpm/pool.d/www.conf
- Code: Select all
listen = /var/run/php5-fpm.sock
to:
- Code: Select all
listen = 127.0.0.1:9000
- Code: Select all
>mkdir /var/www
- Code: Select all
>groupadd www-data
- Code: Select all
>/etc/init.d/nginx restart
- Code: Select all
>/etc/init.d/php5-fpm restart
- Code: Select all
>echo "<?php phpinfo(); ?>" >> /var/www/test.php
@Spurious, nice guide!
Found that a root /var/www; line in the location ~ .php$ { section was missing.
Got FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream errors.
With the root line added it works!
howdy!
big thanx for the many lines put together!
so far almost every stuff went up without shouting for anything. Only the suhosin patches were not found.
however success is still partial. With a localhost browser test it was able to display the htmls i've put into the www dir. but with phps it just bare says: file not found in the browser. its exactly next to the htmls. i pi chowned,755chmodded, still no luck
any idea what can be the reason/ how i could troubleshoot this?
