Wireless keyboard
35 posts   Page 1 of 2   1, 2
by Nodge » Tue Mar 13, 2012 4:30 pm
Can"t seem to find anything on the RS site about what peripherals will be available. I'd like a small wireless keyboard (with trackball or maybe separate mouse). Been having a look on Ebay and found item no 370506970516. Description mentions it's compatible with Linux so can I assume this would be ok for the Raspberry Pi? Would it be plug & play or would I need drivers? Or can anyone recommend something similar?
by Kernel » Tue Mar 13, 2012 4:47 pm
Unfortunately neither RS or Farnell have a list of what is compatible
You can look on the wiki or the forum to see what has been tested so far by people but for the most part we won't know until we get the pi's and more people can test
Generally a keyboard, mouse etc. should be ok due to generic drivers but can't guarantee it
also just because something says linux doesn't mean it will work, it also needs to be compiled for ARM and the specific ARM version the pi has iirc
by Kernel » Tue Mar 13, 2012 4:54 pm
by andytuk » Tue Mar 13, 2012 5:08 pm
I tried to use the Microsoft 800 wireless mouse and keyboard with #7.
The keyboard does not work correctly. Its like keys are getting stuck. The same keyboard runs under linux fine on my PC.
Will see if I can get the wiki updated for this keyboard/mouse.
by Kernel » Tue Mar 13, 2012 5:10 pm
what other kb's have you tried? I assume a generic wired keyboard is fine?
by andytuk » Tue Mar 13, 2012 5:13 pm
I'm currently using a PS/2 to USB adapter cable. Works great.
Have also tried a 'generic' wired USB keyboard. No problems with that one.
by Kernel » Tue Mar 13, 2012 6:17 pm
sounds good - thanks :)
by Montala » Tue Mar 13, 2012 7:45 pm
It would be good if you could use something like a Logitech wireless keyboard and mouse with their tiny USB transmitter/receiver, and I would be very interested to know if one of those would work or not.
by Kernel » Tue Mar 13, 2012 7:51 pm
does it support linux? (not necesarily ARM as that info isn't always available)
by error404 » Tue Mar 13, 2012 8:52 pm
Every wireless keyboard/mouse I have ever seen are just HID devices and will work.
Or they're Bluetooth and will work, but will need a bit of extra software/configuration.
by andytuk » Wed Mar 14, 2012 9:15 am
Tested the Microsoft 800 wireless mouse and keyboard again last night. Keyboard still inst working correctly.
I have updated the Wiki : http://elinux.org/RPi_Verified....._Keyboards
by c17 » Sat May 05, 2012 3:29 pm
Any idea on this one?
http://www.ebay.co.uk/itm/2-4G.....540wt_1037
Nice unit, Bluetooth auto connect with track pad and back lit keyb for under £20. compact. built in rechargeable battery too… says it supports debian 3.1 but will that mean from 3.1 or just 3.1…?
by abstract » Sat May 05, 2012 4:01 pm
This is the one I want to use.  Claims to be Linux compatible.  Is that enough ??
http://www.amazon.co.uk/gp/pro.....B003UE52ME
by artesea » Sun May 06, 2012 7:55 am
Having a similar issue with my Microsoft wireless keyboard. Sometimes the keys go sticky, others non responsive. Nothing too drastic at the moment though.
by canyon » Sun May 06, 2012 8:38 am
I bought this one:
It works fine on a pc with windows 7.
It works on a PS3.
I can't say whether it works on the Raspberry Pi, as mine hasn't arrived yet.
BUT: I have an old pc loaded with Debian Squeeze + LXDE (following Liam's tutorial, missing out the VirtualBox bits) and the keyboard works out of the box with it, no problems.
As a keyboard it's fine, although IMHO it's too small to use as a main keyboard. The touchpad is a bit fussy, but I've got clumsy fingers!
They now do  one with a built in IR controller instead of the laser, I would have bought that one if I'd known about it:
http://www.amazon.co.uk/Rii-I6.....rid_pt_1_2
Also a bluetooth version and a wireless one without the laser or IR.
by Alun » Sun May 06, 2012 6:30 pm
The Microsoft wireless keyboard 800 does not work for me either - same problem as if the keys are stuck then crashes the Pi.
This keyboard does work for me but I bought it a few years ago so don't know of a supplier now:
http://globlink.en.ecplaza.net.....06172.html
by alexeames » Sun May 06, 2012 7:10 pm
Anyone tried the Logitech K260 and M210 keyboard and mouse?
My Pi uses 2 watts - what what? ---- HiRes early production Pi photos RS Front Back | Farnell Front Back
by rmm200 » Sun May 06, 2012 7:30 pm
Keep in mind that wireless keyboards and mice require power (significant?) for the receiver. Sticking keys and crashing Pi's make me think the Pi power supply is marginal. It would help if posters with problems would identify the power supply they are using.
by blueflash » Sun May 06, 2012 10:03 pm
I'm using Trust Wireless Deskset Keyboard and mouse set (£12 from Home Bargains) , with Pi powered from TV usb
by dave_s » Sun May 06, 2012 10:38 pm
The Logitech K400 wireless keyboard works ok, has a pad so don't need the mouse.
I use Masterplug SRGDU42PW as my power source, for raspi and monitor.
by Montala » Mon May 07, 2012 8:10 am
I rather like the look of the Logitech K400, as mentioned above, but no one in the UK appears to have them in stock at the moment.
Perhaps they have all been bought by Raspberry Pi enthusiasts!
Does anyone know of any sources for these please?
by alexeames » Mon May 07, 2012 8:12 am
There's a seller on Amazon £35.99
http://www.amazon.co.uk/Logite.....038;sr=8-1
by MadHorseman » Mon May 07, 2012 8:31 am
I was lucky enough to get a special offer from Logitech Direct (I have a Harmony One remote) with 35% off, so got one for €25.99 inc p&p - works fine with an old laptop.
But - I haven't got a Pi yet....boo hoo!
by Montala » Mon May 07, 2012 9:47 am
Thanks, but I had already just seen that one.
By the time you have added p&p it come out at nearly £42, which is a bit more than I wanted to pay really.
Like a lot of others on here, I haven't received my Pi yet anyway, and as it will be quite a few more weeks before I do, I think I will hang on for a better deal!
by alexeames » Mon May 07, 2012 10:42 am
Montala said:
alexeames said:
There"s a seller on Amazon £35.99
Sorry, I neglected to insert my esp chip this morning. ;) :p
You're right though, it is a pricey beast.
