Setting up VPN on Pi
by atomant » Sun Jun 17, 2012 2:27 pm
How could I set up OpenVPN or some other VPN on my Raspberry Pi? Would the Pi work well for this?
by zardoz99 » Sun Jun 17, 2012 2:36 pm
Server or Client mode?
Z.
by atomant » Sun Jun 17, 2012 2:38 pm
Server
by jecxjo » Sun Jun 17, 2012 3:04 pm
I'm running Arch and went through the install for PPTP via the directions here https://wiki.archlinux.org/index.php/PPTP_Server
It will work pretty good as long as you don't have a ton of connections. Remember all traffic is going through a single ethernet via USB multiple clients will slow things down.
IRC (w/ SSL Support): jecxjo.mdns.org
Blog: http://jecxjo.motd.org/code
ProjectEuler Friend: 79556084281370_44d12dd95e92b1d9453aba2bdc94101b
by jmparound » Sun Jun 24, 2012 7:02 pm
Lo all,
Im not massively experienced with linux and set out to makes the RasPi a PPTP vpn endpoint (as win7 and iPad supports pptp natively). Had quite a few problems along the way but finally got it working. Ive documented my struggles and solutions at http://jmparound.blogspot.co.uk/2012/06 ... erver.html
by JOCO_MKNZ » Tue Jun 26, 2012 3:46 pm
How about an OpenVPN client?
Has anyone had issues with this?
by Mjpyecroft » Wed Apr 23, 2014 10:01 am
Hello i have a pi which has openelec running xbmc. Some of the channels that I would like to watch require a VPN . Is there a way that I can do this ? Kind regards matthew
