No HDMI output on LG TV
29 posts   Page 1 of 2   1, 2
by Tommie » Tue Jun 12, 2012 12:25 pm
I connected my Raspberry to my LG TV via HDMI and loaded the Debian 6 image onto the SD card, but altough I tried tinkering with config.txt and updated my firmware as well, I am still unable to get any video signal on my tv set ("No signal"). At least I am able to use SSH.
This is what read-edid says about the output of /opt/vc/bin/tvservice -d:
pi@raspberrypi:~$ parse-edid edid.dat
parse-edid: parse-edid version 2.0.0
parse-edid: EDID checksum passed.
   # EDID version 1 revision 3
Section "Monitor"
   # Block type: 2:0 3:fc
   Identifier "LG TV"
   VendorName "GSM"
   ModelName "LG TV"
   # Block type: 2:0 3:fd
   HorizSync 28-67
   VertRefresh 50-75
   # Max dot clock (video bandwidth) 150 MHz
   # DPMS capabilities: Active off:yes  Suspend:yes  Standby:yes
   Mode    "1360x768"   # vfreq 59.799Hz, hfreq 47.720kHz
      DotClock   84.750000
      HTimings   1360 1432 1568 1776
      VTimings   768 771 776 798
      Flags   "+HSync" "-VSync"
   EndMode
   Mode    "1280x768"   # vfreq 60.352Hz, hfreq 48.161kHz
      DotClock   80.140000
      HTimings   1280 1344 1472 1664
      VTimings   768 771 778 798
      Flags   "-HSync" "-VSync"
   EndMode
EndSection
I tried setting various options in /boot/config.txt, but with no actual success.
pi@raspberrypi:~$ /opt/vc/bin/tvservice -s
state: HPD low|HDMI off|NTSC mode|composite CP off (0x140001), 720x480 @ 60Hz, interlaced
pi@raspberrypi:~$ /opt/vc/bin/tvservice -p
Powering on HDMI with preferred settings
[E] Failed to power on HDMI with preferred settings
Any advice?
by dom » Tue Jun 12, 2012 12:33 pm
"state: HPD low" is the problem. Make sure monitor is powered on and on right input setting before booting pi.
If no luck, try hdmi_force_hotplug=1
(see here: http://elinux.org/R-Pi_Troubleshooting# ... put_at_all)
by extravagoose » Tue Jun 12, 2012 12:35 pm
I had this issue with Arch - I first tried simply renaming or move the config.txt file to another directory... or just wipe its contents. This seemed to work for me. Of course this may bare no relevance to Debian or indeed you setup.
But as said by dom,
try using hdmi_force_hotplug=1
RPi 1: Hostname: Gimli, 500Gb USB HDD, ArchLinux | ARM.
Main Use: Bit of everything - but mainly web server, Network Storage and C programming.
RPi 2: Hostname tba, awaiting delivery.
by Tommie » Sun Jun 17, 2012 12:12 am
Using this config.txt, I still do not get a picture on my TV:
root@raspberrypi:/home/pi# cat /boot/config.txt
sdtv_mode=2
config_hdmi_boost=5
hdmi_drive=2
root@raspberrypi:/home/pi# /opt/vc/bin/tvservice -s
state: HPD high|HDMI mode|HDCP off|composite off (0x12001a), 1280x768 @ 60Hz, progressive
root@raspberrypi:/home/pi# /opt/vc/bin/tvservice -m CEA
Group CEA has 16 modes:
           mode 1: 640x480 @ 60Hz, progressive
           mode 2: 720x480 @ 60Hz, progressive
           mode 3: 720x480 @ 60Hz, progressive
           mode 4: 1280x720 @ 60Hz, progressive
  (native) mode 5: 1920x1080 @ 60Hz, interlaced
           mode 7: 720x480 @ 60Hz, interlaced
           mode 16: 1920x1080 @ 60Hz, progressive
           mode 17: 720x576 @ 50Hz, progressive
           mode 18: 720x576 @ 50Hz, progressive
           mode 19: 1280x720 @ 50Hz, progressive
           mode 20: 1920x1080 @ 50Hz, interlaced
           mode 22: 720x576 @ 50Hz, interlaced
           mode 31: 1920x1080 @ 50Hz, progressive
           mode 32: 1920x1080 @ 24Hz, progressive
           mode 33: 1920x1080 @ 25Hz, progressive
           mode 34: 1920x1080 @ 30Hz, progressive
root@raspberrypi:/home/pi# /opt/vc/bin/tvservice -m DMT
Group DMT has 4 modes:
           mode 4: 640x480 @ 60Hz, progressive
           mode 9: 800x600 @ 60Hz, progressive
           mode 16: 1024x768 @ 60Hz, progressive
           mode 23: 1280x768 @ 60Hz, progressive
How ever, no picture and TV indicating "NO SIGNAL".
by steveastrouk » Sun Aug 05, 2012 5:58 pm
Tommie,
I have exactly the same problem - I've even updated my telly's firmware, but no joy.
Did you EVER get the thing working ?
Steve
by proyecto » Sun Aug 19, 2012 1:55 pm
Exactly the same problem. Not working yet.
http://www.twitter.com/proyecto
http://www.enigmatres.es
by steveastrouk » Sun Aug 19, 2012 3:27 pm
proyecto wrote:Exactly the same problem. Not working yet.
Balls. Me neither, but it MIGHT be worth unplugging the TV and trying again when it restarts.
Steve
by dom » Sun Aug 19, 2012 3:41 pm
Make your you've got recent firmware (official wheezy/raspbian shoud be okay) and try
hdmi_safe=1
In config.txt.
by steveastrouk » Sun Aug 19, 2012 4:00 pm
I've tried several HDMI hacks in the config file, and they didn't work. Will try the latest distribution though.
Steve
by proyecto » Sun Aug 19, 2012 4:30 pm
I have also tested all the config hacks I have seen on the web, updated firmware with the latest Raspbian version, and nothing.
The same Raspi works perfectly in a samsung tv.
by steveastrouk » Sun Aug 19, 2012 4:53 pm
proyecto wrote:I have also tested all the config hacks I have seen on the web, updated firmware with the latest Raspbian version, and nothing.
Trying the new firmware any minute. I'll concur shortly....
What the heck is it with LG and PI ?
Which TV have you got proyecto ?
Steve
by steveastrouk » Sun Aug 19, 2012 5:24 pm
OK, Latest Raspbian,STILL no luck,
Hotplug set to 1
Safe mode set to 1
by proyecto » Sun Aug 19, 2012 7:22 pm
Latest Raspbian, latest firmware updated via Hexxeh tool. Not working even with the config.txt hacks commented above.
My tv: http://www.lg.com/es/monitores/lg-M2780D-PZ-monitor
state: HPD high|HDMI mode|HDCP off|composite off (0x12001a), 640x480 @ 60Hz, progressive
Group CEA has 1 modes:
by dom » Mon Aug 20, 2012 10:56 am
@steveastrouk @proyecto
Can you dump your edids and attach them to response (you will need to zip them)
/opt/vc/bin/tvservice -d edid.dat
@steveastrouk what is the exact model?
by steveastrouk » Mon Aug 20, 2012 11:43 am
37LG6000
by proyecto » Wed Sep 26, 2012 8:48 pm
Back again, not able to make it work yet. Attached edid.dat zipped.
edid.dat.zip
(815 Bytes) Downloaded 117 times
by deimusmeister » Wed Nov 28, 2012 11:42 pm
Is there any update on this ? seems rapsberry has a problem to connect to LG TVs
by dom » Thu Nov 29, 2012 2:37 pm
proyecto wrote:Back again, not able to make it work yet. Attached edid.dat zipped.
Nothing surprising in edid.dat. With hdmi_safe=1 we are outputting a manditory HDMI mode, and we are hdmi compliant.
Possibilities are:
a hardware fault on Pi. If you can drive other monitors, then that seems unlikely.
a hardware fault on TV or with HDMI cable. Can you definitely drive this monitor from another source, using the same HDMI cable and HDMI input port on TV?
Other settings to randomly try: (remove hdmi_safe and other settings first)
Always add:
config_hdmi_boost=7
Try combintation of:
hdmi_drive=1
or
hdmi_drive=2
hdmi_group=1
or
hdmi_group=2
hdmi_mode=<mode>
with modes listed here:
http://elinux.org/RPi_config.txt
by zwg_zero » Fri Nov 30, 2012 6:33 am
try add this line in config.txt (ignore reading TV's edid message)
hdmi_ignore_edid=0xa5000080
by deimusmeister » Thu Dec 06, 2012 8:04 pm
what address is that 0xa5000080 ?
In my case it might be another
by deimusmeister » Thu Dec 06, 2012 8:08 pm
@dom can you please review my edid as well ?
edid.dat.txt.zip
(1.34 KiB) Downloaded 93 times
by proyecto » Thu Dec 06, 2012 8:36 pm
zwg_zero wrote:try add this line in config.txt (ignore reading TV's edid message)
I will try it next week. Thanks!
by deimusmeister » Thu Dec 06, 2012 9:13 pm
I'm just surfing, seems there is a widespread issues for LG HDMI inputs, anyway I don't have another HDMI device to test the tv :(
by zwg_zero » Fri Dec 07, 2012 9:38 am
by aaa801 » Fri Dec 07, 2012 11:56 am
works fine on my lg tv
