Cannot install packages using apt-get
by imcrpi » Wed Oct 23, 2013 2:16 am
I've noticed that many people have been having this issue, but I can't seem to find an answer. I tried installing a package called libgles2-mesa for OpenGL work, but I get these errors...
root@raspberrypi:~# apt-get install libgles2-mesa
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
  libgles2-mesa
0 upgraded, 1 newly installed, 0 to remove and 36 not upgraded.
11 not fully installed or removed.
Need to get 0 B/39.0 kB of archives.
After this operation, 110 kB of additional disk space will be used.
Setting up initscripts (2.88dsf-41+deb7u1) ...
insserv: warning: script 'S99eth0disable' missing LSB tags and overrides
insserv: warning: script 'eth0disable.sh' missing LSB tags and overrides
insserv: There is a loop at service eth0disable if started
insserv: There is a loop between service plymouth and mountnfs if started
insserv:  loop involving service mountnfs at depth 8
insserv:  loop involving service networking at depth 7
insserv: There is a loop between service eth0disable and mountall if started
insserv:  loop involving service mountall at depth 5
insserv:  loop involving service checkfs at depth 4
insserv:  loop involving service urandom at depth 7
insserv: There is a loop at service plymouth if started
insserv: There is a loop between service plymouth and mountall-bootclean if started
insserv:  loop involving service mountall-bootclean at depth 1
insserv:  loop involving service kbd at depth 10
insserv: Starting eth0disable.sh depends on plymouth and therefore on system facility `$all' which can not be true!
insserv: Max recursions depth 99 reached
insserv:  loop involving service apache2 at depth 1
insserv: There is a loop between service eth0disable and mountkernfs if started
insserv:  loop involving service mountkernfs at depth 1
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing initscripts (--configure):
 subprocess installed post-installation script returned error exit status 1
 initscripts
I've been dealing with this for a while now, and it would be great to figure out what is going on.
Thank you.
- Ian
by joan » Wed Oct 23, 2013 7:56 am
Is plymouth installed by default? It may not have installed properly.
by imcrpi » Wed Oct 30, 2013 11:31 pm
I'm not sure if it's a default package or not, but I don't remember installing it on there. How would I reinstall or remove it without formatting my SD card?
by confuseling » Thu Oct 31, 2013 12:59 am
Plymouth is a package like any other. You should be able to remove it with apt-get or aptitude (or synaptic, or...)
http://forums.debian.net
