Can not get g++ to compile on Pi
by tuxtux » Thu Aug 29, 2013 11:14 am
Hi Guys,
After looking around, googling and searching for something suitable for Modbus, I have found
some software but can not get it to compile.
My knowledge is close to 0 on writing code (C++) but I have tried compiling some source on "big" machines before. I have done some Perl programming.
Here is the issue at hand:
The code I am trying to compile is at:
http://www.modbusdriver.com/modpoll.html
When invoking g++ in any number of ways and with any number of switches, I can not get it to work.
There are 4 files required as "FieldTalk package headers"
MbusAsciiMasterProtocol.hpp
MbusRtuMasterProtocol.hpp
MbusRtuOverTcpMasterProtocol.hpp
MbusTcpMasterProtocol.hpp
I have put them together in the /usr/include directory as they did not work
in the directory where I compiled them, despite trying to tell the compiler where to find them.
This is one of my typical results.
g++ Wall -c modpoll.cpp
In file included from modpoll.cpp:40:0:
MbusRtuMasterProtocol.hpp:35:40: fatal error: MbusSerialMasterProtocol.hpp: No such file or directory
compilation terminated.
I know it is little info but I'm lost. If I can not even get this to go, there is little hope
of me ever getting a Modbus master going to read my measurement meter.
I have installed libmodbus and libmodbus-dev to see if I could write some
code using those libraries but have no sample code at all:-(
So, I'm not expecting someone to do it all for me, just point me the right way
so I can get something going.
There are no Make files for the code.
Edit: Forgot to mention, I am running standard Wheezy with all updates applied, all working good.
by SteveSpencer » Thu Aug 29, 2013 1:19 pm
A couple of things;
how were you telling the compiler where to find the hpp files? Presumably a g++ option, but which one?
Secondly, the hpp files refer to other hpp files you haven't copied. This is obvious from the error message:
The first part is the file that caused the problem, along with a line and column number (35 and 40 respectively). The second part ('fatal error:' and onward is telling what the problem is.
You need to check the hpp files and see what other headers they need.
Steve
Steve S
No, I can't think of anything funny that won't offend someone if they want it to...
by tuxtux » Sun Sep 01, 2013 11:42 am
I will have a closer look, think the serial bus .hpp file is missing.
Will go through it and make sure all .hpp files are present.
Thanks, will give an update when all tested.
