Strange serial behavior? [SOLVED]
by Zerpudo » Sun Aug 18, 2013 12:17 pm
SOLVED!
I'm sending data (chars) from an Arduino via serial to a RPI. I'm receiving the data well on RX (cat /dev/ttyAMA0 to see it) , but I don't know why, the RPI is forwarding back the received data through TX to Arduino again! I still haven't told RPI what to do with those message coming in RX GPIO, so I don't understand why is it sending back to Arduino.
Any ideas? Thank you so much in advance!
by joan » Sun Aug 18, 2013 12:25 pm
What does
stty -F /dev/ttyAMA0
report on the Pi?
by Zerpudo » Sun Aug 18, 2013 12:54 pm
Thank you for the response. I did what you told me and this is what I get:
speed 9600 baud; line = 0;
-brkint -imaxbel
by joan » Sun Aug 18, 2013 1:16 pm
You might need to disable echo
stty -F /dev/ttyAMA0 -echo -echoe -echok
by Zerpudo » Sun Aug 18, 2013 1:27 pm
Thank you SO much man, it worked perfectly!! So grateful :)
Cheers!
by joan » Sun Aug 18, 2013 1:29 pm
That's fortunate because that was my only idea! :D
by Zerpudo » Sun Aug 18, 2013 1:42 pm
Haha, well done :)
Just one thing. It must be easy but I don't know how to do it since I'm a noob! I realized that if I reboot my RPI the configuration resets again. How could I do to make it permanent?
by joan » Sun Aug 18, 2013 1:58 pm
Personally I'd add a reboot crontab entry.
sudo crontab -e
@reboot              /bin/stty -F /dev/ttyAMA0 -echo -echoe -echok
There are plenty of other ways.
