RAspberry Pi running hot?
by toprobin » Wed Aug 14, 2013 1:48 am
i am running 700Mhz, not overclocking, running the usual services - samba, LAMP stack, mpd, a few others
a "/opt/vc/bin/vcgencmd measure_temp" usually returns 55 degrees C or so, gets over 60 degrees when I am streaming. I've seen it hit 64 degrees for an extended period of time.
Should I be concerned?
by ShiftPlusOne » Wed Aug 14, 2013 5:42 am
No, that's quite cold. Start getting a little worried if it gets over 75.
by toprobin » Wed Aug 14, 2013 12:23 pm
Ok - thanks for the guidance. I don't ever see it run above 70, but I'm now monitoring it.
