Help with a startup script.
by T800 » Mon Aug 05, 2013 8:50 pm
Can someone help me with some sort of startup script for when the Pi boots.
Once the Pi has started I SSH in and send these commands via terminal on my mac:
mkdir /tmp/stream
cd /home/pi/mjpg-streamer/mjpg-streamer
LD_LIBRARY_PATH=./ ./mjpg_streamer -i "input_file.so -f /tmp/stream" -o "output_http.so -w ./www"
I then open another terminal and send:
raspistill -w 1280 -h 720 -q 5 -o /tmp/stream/pic.jpg -tl 10 -t 10000000 -th 0:0:0 &
Can anyone help me?
by kghunt » Mon Aug 05, 2013 8:58 pm
First step is to put all your commands in an .sh file and make it executable with
chmod a+x filename.sh
Run this script manually to make sure it has the desired output.
./filename.sh
Then edit crontab
crontab -e
And add this
@reboot sh /pathtofile/filename.sh &
The ampersand at the end backgrounds the process so it doesn't hold up booting while the script runs.
There are other methods but this is the easiest to get started.
by T800 » Mon Aug 05, 2013 9:23 pm
Thanks for that I will give it a go.
by T800 » Thu Aug 08, 2013 3:03 pm
I did all that and it worked a treat. I now have a fully capable CCTV ip camera that starts up and streams on boot.
Thanks again.
by Joe Schmoe » Thu Aug 08, 2013 3:32 pm
I don't think you need the & in the crontab. I've never used @reboot myself, but you should never need an & in a crontab file entry.
Still, it may be a good idea, given that it can be scary when you put something in one of these startup scripts and it causes the boot process to hang (I'm thinking more of rc.local here).
Oh, how I wish that the signature facility on this board weren't so broken.
It is broken in that every time you change your signature, all of your posts reflect the change, not just those going forward.
by kghunt » Thu Aug 08, 2013 6:30 pm
You are probably right. @reboot does work though. I have a python script that I run from cron every 12 hours. It posts information about my pi (load,local ip, public ip etc) into a google spreadsheet. I use at reboot to call it at boot too.
by T800 » Tue Aug 27, 2013 6:35 am
This has been working great for a while now with only one issue.
raspistill -w 1280 -h 720 -q 20 -o /tmp/stream/pic.jpg -tl 10 -t 1000000000 -th 0:0:0 &
The time the camera is set to run for is 11 days (-t 1000000000) and after that I need to reboot the pi. If I set it one digit higher (115 days) it doesn't run. To get this fully auotmatic I need a higher run time for the camera or for the pi to reboot itself every week.
Is there a weekly reboot script I can run?
by rpdom » Tue Aug 27, 2013 7:10 am
T800 wrote:Is there a weekly reboot script I can run?
You could use the "@weekly" crontab option, which is the same as putting "0 0 * * 0", meaning "run this at 00:00 on day 0 (Sunday) of every week". It would probably be best if you put a line in the root crontab for this, so
sudo -e crontab
and add a line like
@weekly /sbin/shutdown -r now
