Replacement desktop?
by dan3008 » Mon Aug 05, 2013 5:46 pm
Hi everyone
I've got a menu system working, and now I want to implement it on my pi for testing. The problem I am having, is that its an X application, but i want it to replace the normal desktop in raspien.
In windows, I can change the shell easily, but i dont know how to do this in raspien, or arch, or any linux. Any hints would be gratiously recived.
Dan
dan3008 wrote:Pays your money, takes your choice
by dan3008 » Tue Aug 06, 2013 1:42 pm
Is this even doable? I've been looking at using open box, or xinit but not having much luck yet :/
by RaTTuS » Tue Aug 06, 2013 1:48 pm
what desktop ,
I don't understand what you want to change
http://www.catb.org/esr/faqs/smart-questions.html Ask Questions
http://www.raspberrypi.org/forums/viewtopic.php?f=29&t=7192 AutoStart Script
"That's not right, the badgers have moved the goalposts."
by dan3008 » Tue Aug 06, 2013 2:02 pm
The desktop enviroment. When you start the X server using startX on raspien, you are met with a wallpaper, menu and desktop icons. Thats what i want to replace. I have a new menu system that I want to replace the default. And i'm not sure how to do it.
In windows its called the shell, and can be changed through a simple regestery change, from wndows explorer to whatever you want
by duberry » Tue Aug 06, 2013 3:02 pm
i think the desktop used in raspbian is lxde aka "Lightweight X11 Desktop Environment"
lend me your arms, fast as thunderbolts, for a pillow on my journey.
If the environment was a bank, would it be too big to fail
so long; and thanks for all the pi
Location: standing on a planet that's evolving. And revolving at nine hundred miles an hour
by ghans » Tue Aug 06, 2013 3:23 pm
startx starts xinit , and xinit executes whatever is in your
.xinitrc ( a hidden file in your home directory).
So modify your .xinitrc to execute your program.
ghans
by Joe Schmoe » Tue Aug 06, 2013 3:46 pm
ghans wrote:startx starts xinit , and xinit executes whatever is in your
ghans
To amplify on this, this is the contents of my .xinitrc file (on a Pi/Raspbian system):
# This file has 5 lines in it (including this one)
xsetroot -solid pink
xclock &
xscreensaver &
openbox & exec lxterminal
Notes:
1) Make sure .xinitrc is executable (chmod +x ~/.xinitrc)
2) Make sure "openbox" is installed (apt-get install openbox)
Faced with the choice between changing one's mind and proving that there is
no need to do so, almost everyone gets busy on the proof.
- John Kenneth Galbraith -
by dan3008 » Tue Aug 06, 2013 3:48 pm
Ah brilliant :D
thank you Ghans :)
I'm glad its that easy really :) I knew it must be, but my linux foo is not what it needs to be, but i'm getting there :)
thanks for the aditional help Joe
by dan3008 » Tue Aug 06, 2013 4:10 pm
Thanks again everyone
I've had a play and it seems to be working :) Need to have a proper play, and actually get my menu up and running :)
thanks a million
