List of games for Raspberry Pi
40 posts   Page 2 of 2   1, 2
by AndrewS » Thu Jun 21, 2012 10:43 am
I believe most USB joysticks just appear as standard HID devices, so should just be plug'n'play (literally!) :D
by Condemned » Thu Jun 21, 2012 10:46 am
RaTTuS wrote:nethack works fine ;-p
I've installed Angband:
sudo apt-get install angband
The 'SDL' front end (?) for it seems to run very quickly in the debian/raspbian desktop. I launch it from an LXTerminal window using:
angband -msdl -uCharacterName
My children (7 & 9) are hooked, and interest hasn't waned for a couple of weeks now. We've had to set up a rota to prevent (real world) fighting.
Nigel Batten
www.batsocks.co.uk
by Pygar » Thu Jun 21, 2012 3:47 pm
My thanks for the replies... Hmm... "mame"? "xwindows"? Looks like I have some learning to do. As far as the "plug and play" joysticks go... I have an IPazzPort wired keyboard that is supposed to be Plug and Play but when connected to RPi is "Plug and Inert Object". I'll look later in the List of Peripherals that Work and see if there's a cheap joystick...
"Mean kitty, bad kitty
Vicious ball of fur!
Fighty kitty, bitey kitty!
Grrr! Grrr! Grrr!"
by Onyros » Sun Jul 08, 2012 12:53 am
ScummVM works pretty well, too, at least on Arch. No real fullscreen yet, as of version 1.4.1, but apart from that it's recommended from this side.
I tried Secret of Monkey Island, Indiana Jones and the Last Crusade, Gobliiins and Leisure Suit Larry (the original!).
Still have to try Full Throttle, but I suspect it'll be a little slower. Gobliiins, though playable, is also a little slower than the rest.
by BenWiley4000 » Sun Jul 08, 2012 6:06 pm
Here's my testing experience (I run overclocked with 850 arm, 350 core, 500 sdram, so I can't guarantee ALL of my games listed as working will run.. but most will):
WORKS:
ace-of-penguins
atris
blobwars (possibly some lag)
freedink
frozen-bubble (lag without overclock)
gtetrinet
gtkboard
lbreakout2
njam
pacman
petris
supertux
tmw (lags some, might not with substantial overclock)
tuxtype
wesnoth (slow loading times, gameplay seems fine)
wing
xbomb
xinv3d
xjump
DON'T WORK:
gnujump (requires opengl for acceleration)
freeciv (crashed for me when trying to connect to localhost; may be result of attempting to run server and client on same machine)
openttd (error on startup, may work if remedied)
widelands (start and load was taking so phenomenally long that I gave up, though it was definitely at least loading)
by thexman » Sun Jul 08, 2012 7:54 pm
AndrewS wrote:I believe most USB joysticks just appear as standard HID devices, so should just be plug'n'play (literally!) :D
Hid compatible version 1 or 1.1 currently don't work on the PI non of them due to an error in the Blob i believe theres a post in the trouble section about it and the foundation are still to post a fix for it.
one armed controls engineer, my grammar is bad but lets face it most keyboards don't suit a one armed man
by Noobest of them all » Sun Jul 08, 2012 7:56 pm
The online magazine "Magpi" had a list of games in the third number: http://www.themagpi.com/
I tried Zangband and it seemed to work fine.
by minitweak » Sun Jul 29, 2012 4:54 am
Hey Y'all
Just though I would let you know that most of the games on http://www.abandonwarering.com/ or http://homeoftheunderdogs.net/ should work with DOSBox and it beats trying to get your copies of ancient games off of 3'1/2 in. and 5' 1/4 in. floppies or even (god forbid) 10 and 20 meg HDDs for use with your Pi. http://cd.textfiles.com also has some nice old goodies that should work through Pi with an emulator
by owen_a » Wed Dec 12, 2012 10:36 pm
mrbill wrote:I wonder if the java4k games might run
http://www.java4k.com
Anyone got java working?
Yeah,
apt-get install openjdk-7-jre
by xranby » Thu Dec 13, 2012 12:57 am
Yeah,
To install the java browser plugin and javaws java webstart jnlp launcher:
apt-get install icedtea-7-plugin
For more java applet testing follow this thread:
viewtopic.php?f=81&t=25514
You can also start the java4k games using the appletviewer found in the openjdk-7-jdk package
appletviewer http://www.java4k.com/index.php?action=games\&method=view\&gid=417
Xerxes Rånby @xranby I once had two, then I gave one away. Now both are in use every day!
twitter.com/xranby
by Foxbat » Thu Dec 13, 2012 1:07 pm
I can verify that Ultima 7 (Exult engine) works on the Pi.
by m1n1m3 » Tue Jan 22, 2013 10:14 pm
Toad King wrote:What about Nethack? :P
theres a nethack download for pi (sudo apt-get install nethack-console) theres also a clone called nitrohack believe
by Magic Knight » Wed Jan 23, 2013 10:07 am
There are 1,000's of games available for the ZX Spectrum using the Fuse emulator
Open a terminal from the desktop and type
sudo apt-get install fuse-emulator-gtk
sudo apt-get install spectrum-roms
Fuse is automatically added to the Games menu
Then pop along to http://www.worldofspectrum.org/
click on the archive link and download some games, most have full instructions available.
Here's one of my favourites http://www.worldofspectrum.org/infoseek ... id=0004744 :)
Tips - when running Fuse, click Options - Filter... to increase the window size, I use Double size
and click Machine - Select..... to change between 48k and 128k
Have fun
Magic Knight
by ulysess » Wed Jan 23, 2013 10:40 am
Magic Knight wrote:There are 1,000's of games available for the ZX Spectrum using the Fuse emulator
I recommend Speccy ;) http://misapuntesde.com/post.php?id=49
Mis apuntes de...Raspberry Pi: http://misapuntesde.com
Google Docs RPi: http://goo.gl/Iwhbq
by SimonSmall » Wed Jan 23, 2013 4:17 pm
I have tried Dungeon Crawl (sudo apt-get install crawl) and it works fine in command line mode (and using SSH). It is a Rogue-like dungeon adventure game
I tried crawl-tiles, the graphical version, and I got some errors in the X11 log. I have not had a chance to look into these yet, but I hope it works
