C++11 <thread>: no matching function for call
by theColonel26 » Thu Jul 18, 2013 4:20 pm
I'm getting this on build
no matching function for call to 'std::thread::thread(<unresolved overloaded function type>)'
for the line
thread thread1(run);
here is the the class
class Blinker
   private:
      volatile bool boolStop;
      bool step[6];
      void run()
         timer t1;
         t1.setInterval(4);
         for(;;)
            if(t1.elapsed() < .5 && !step[0])
               digitalWrite(200, 1);
               step[0] = true;
            else if (t1.elapsed() < 1.0  && !step[1])
               digitalWrite(201, 1);
               step[1] = true;
            else if (t1.elapsed() < 1.5  && !step[2])
               digitalWrite(200, 0);
               step[2] = true;
            else if (t1.elapsed() < 2.0  && !step[3])
               digitalWrite(201, 0);
               step[3] = true;
            else if (t1.elapsed() < 2.5  && !step[4])
               step[4] = true;
            else if (t1.elapsed() < 3.0  && !step[5])
               step[5] = true;
            else if (t1.elapsed() > 4.0)
               for(int i = 0; i < sizeof(step); i++)
                  step[i] = 0;
               t1.reset();
            if (this->boolStop)
               break;
   public:
      Blinker()
         boolStop = false;
      void start()
      void stop()
         boolStop = true;
by elektrknight » Thu Jul 18, 2013 4:56 pm
What are the includes and what compiler are you using?
Placek Malinowy to jest to!
by theColonel26 » Thu Jul 18, 2013 5:30 pm
extern "C" {
#include <wiringPi.h>
#include <piFace.h>
#include <iostream>
#include <ctime>
#include <thread>
I'm using the G++ 4.6
by AndyD » Thu Jul 18, 2013 10:13 pm
A class member function needs to be bound to a class object:
theColonel26 wrote:
      void start()
To create a thread using a class member function you need to pass the "this" pointer as the second parameter to the std::thread constructor:
      void start()
         thread thread1(run, this);
by theColonel26 » Fri Jul 19, 2013 1:16 pm
Ok I tried your suggestion, but I'm still getting the same error. :(
by AndyD » Fri Jul 19, 2013 10:24 pm
Here is a cut down version that compiles
#include <iostream>
#include <ctime>
#include <thread>
using namespace std;
class Blinker
   private:
      void run()
   public:
      Blinker() : boolStop(false)
      void start()
         thread thread1(&Blinker::run, this);
      void stop()
         boolStop = true;
int main(void)
    Blinker blinker;
    blinker.start();
    while(1)
        // do nothing
    return 0;
compiled using
g++ -std=c++0x -pthread blinker.cxx -o blinker
Edit: This now compiles, but what do you expect the code to do when thread1 is destroyed at the end of start()? You will need to call thread1.detach() in the start() method.
by theColonel26 » Tue Jul 23, 2013 1:40 pm
thanks, I got it to compile finally.
this is what I needed
thread1 = thread(&Blinker::run, this);
I was using this which didn't work.
thread1 = thread(run, this);
what is the difference though? I assume the top one must be passing a reference to the function. So the bottom one is pass by copy syntax. which probably isn't possible for a function right?
by AndyD » Tue Jul 23, 2013 11:42 pm
theColonel26 wrote:what is the difference though? I assume the top one must be passing a reference to the function.
The top one is passing a pointer to a member function (there are no function references in C++ only pointer to functions). The difference is that in C++ to take the address of a member function run in class Blinker the syntax is &Blinker::run. For non-member functions C++ uses the same syntax as C. In C (lets say you had a function void stop(void);) &stop would give you the address of function stop, however you can drop the ampersand (&) and just use stop.
theColonel26 wrote:So the bottom one is pass by copy syntax. which probably isn't possible for a function right?
No, this isn't about pass-by-value vs pass-by-reference. C++ doesn't have function references only function pointers. A pointer to member function is different to a pointer to non-member function as you need to specify the class and the function (and use an ampersand) when taking the address.
I hope that helps.
