Cron Task URL Access
by Darth » Mon May 13, 2013 6:01 pm
Hi All
I'm trying to use a cron task to auto-reboot my IP Camera (Foscam FI9802W) every 24 hours, current firmware is poor and FTP/NAS access lock up on a regular basis if not rebooted.
If I use the following URL in Midori my Camera will reboot:
http://192.168.1.20:88/cgi-bin/CGIProxy ... x&pwd=xxxx
So, I thought why not generate a Cron Task (crontab -e) to automate the process, after a bit of research I've come up with the following but for the life of me I cannot get it to work; anyone any suggestions to why and how to solve it:
59 23 * * * user/bin/wget -O - -q -t 1 http://192.168.1.20:88/cgi-bin/CGIProxy ... x&pwd=xxxx
Please be gentle, I'm fairly new to Linux.
by rpdom » Mon May 13, 2013 6:22 pm
Darth wrote:user/bin/wget
That should be /usr/bin/wget
by Darth » Mon May 13, 2013 7:08 pm
rpdom
Many thanks for getting back to me so quickly, yep my syntax was poor but I've just tried the following command:
02 20 * * * /usr/bin/wget -O - -q -t 1 http://192.168.1.20:88/cgi-bin/CGIProxy ... x&pwd=xxxx
And it also did not work, any other suggestions greatly welcomed.
by richardp » Mon May 13, 2013 7:19 pm
Darth wrote:rpdom
1) Place the http://xxxxxxxxxxxxxxxxxxxxxxxx&xxx&xxx part in double quotes (") - the & might be being interpreted as the 'Background task'
2) Try making a script and putting it in /usr/bin
#!/bin/sh
/usr/bin/wget -O - -q -t 1 http://192.168.1.20:88/cgi-bin/CGIProxy.fcgi?cmd=rebootSystem&usr=xxxx&pwd=xxxx
chmod +x [your script name]
Then you can place your script name in the CRON file to execute. you can also test the script by running it manually to see the output. Again, put the http:// URL in double quotes.
Richard
RaspberryPi's galore
Solid run CuBox
ODroid U2
by Darth » Mon May 13, 2013 7:24 pm
Richard
Many thanks, the double quotes solved the problem. I just love my little Pi.
Dave
