ssh_exchange_identific issue since latest ssh app update
by plus » Wed Apr 17, 2013 2:58 pm
Hi guys,
my problem is that ssh doesn't work anymore for me between 2 raspis on different networks :(
It began since the last application update (2 or 3 months ago? more or less).
I receive the well known: ssh_exchange_identification!!
pi@raspberrypi:~$ ssh -vv -p 2222 pi@151.41.xxx.xxx
OpenSSH_6.0p1 Debian-4, OpenSSL 1.0.1e 11 Feb 2013
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to 151.41.xxx.xxx [151.41.xxx.xxx] port 2222.
debug1: Connection established.
debug1: identity file /home/pi/.ssh/id_rsa type -1
debug1: identity file /home/pi/.ssh/id_rsa-cert type -1
debug1: identity file /home/pi/.ssh/id_dsa type -1
debug1: identity file /home/pi/.ssh/id_dsa-cert type -1
debug1: identity file /home/pi/.ssh/id_ecdsa type -1
debug1: identity file /home/pi/.ssh/id_ecdsa-cert type -1
ssh_exchange_identification: Connection closed by remote host
I really need ssh :( please help me 'cause on the server side I do not see anything wrong on hosts.allow/deny or /var/run directory permissions....
On local network it works like a charm but port 2222 is properly forwarded on my router so it SHOULD work..
thanx!
by TxBobS » Sun May 05, 2013 6:41 pm
Did you ever get around this?
by plus » Sun May 05, 2013 9:19 pm
unfortunately, no! :( it's really a mistery......
by lmarmisa » Mon May 06, 2013 12:38 am
Try to rename (or even remove) the folders .ssh on both home folders and check if the problem is solved:
cd
ls -la .ssh
mv .ssh ssh
Best regards,
Luis
by balta » Tue May 07, 2013 12:35 pm
lmarmisa wrote:Try to rename (or even remove) the folders .ssh on both home folders and check if the problem is solved:
cd
ls -la .ssh
mv .ssh ssh
Best regards,
Luis
Just tried this and no luck ... I'm restarting my router (just in case) but I'm afraid I'll have to brutally unplug it :cry:
by lmarmisa » Tue May 07, 2013 1:10 pm
I believe this link could help you:
http://edoceo.com/notabene/ssh-exchange-identification
I have seen a couple of cases where problem was solved adding this line to file /etc/hosts.allow
sshd: ALL
