Custom Punnet Card Case + Download
by Dreeass » Mon Apr 08, 2013 6:31 pm
When I was looking for a case for my Raspberry Pi, I came across the Punnet post by "E" on this forum. When I took a look at the PDF that was attached to it, I didn't really like the look of some stuff and I changed it. What I changed was the following:
  • The font changed from Sans to Calibri
  • Simple adjustments to the size, placement and multiple versions
  • A Raspberry Pi logo added on the front with the text Raspberry Pi and the owner's name beneath
  • A second SVG file for the background of the case
How to print it out yourself
  1. Download the ZIP-file and extract it
  2. Open one of the desired SVG files for the outside of the case with Inkscape or any other vector program
  3. Change "Your name here" to your name
  4. Export both the inside and outside SVG files to the desired dpi (Shift+Ctrl+E on Inkscape)
  5. Print both files on one paper and you're done
Image Image Image Image Image
Increase attachment and avatar size limit or use a third party system?
by Dreeass » Tue Apr 09, 2013 5:32 pm
I have just made a new version, now with or without a front panel so you can access the GPIO.
