//mirrordirector.raspbian.org/.... ?
by gordon77 » Fri Apr 05, 2013 4:02 pm
Is there a problem ?
I can't 'apt get install' anything at present
Gordon77
by azeam » Fri Apr 05, 2013 4:06 pm
gordon77 wrote:Is there a problem ?
Gordon77
Yes, it seems so. Can't update either.
by plugwash » Fri Apr 05, 2013 4:16 pm
Seems fine to me, can you post the exact errors you are getting?
by azeam » Fri Apr 05, 2013 4:18 pm
plugwash wrote:Seems fine to me, can you post the exact errors you are getting?
Short hickup, it's working here again. In case you want to know anyway
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/wheezy/Release.gpg  Could not connect to mirrordirector.raspbian.org:80 (89.16.177.202). - connect (110: Connection timed out)
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/wheezy/main/binary-armhf/Packages  Unable to connect to mirrordirector.raspbian.org:http:
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/wheezy/contrib/binary-armhf/Packages  Unable to connect to mirrordirector.raspbian.org:http:
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/wheezy/non-free/binary-armhf/Packages  Unable to connect to mirrordirector.raspbian.org:http:
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/wheezy/rpi/binary-armhf/Packages  Unable to connect to mirrordirector.raspbian.org:http:
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/wheezy/contrib/i18n/Translation-en_GB  Unable to connect to mirrordirector.raspbian.org:http:
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/wheezy/contrib/i18n/Translation-en  Unable to connect to mirrordirector.raspbian.org:http:
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/wheezy/main/i18n/Translation-en_GB  Unable to connect to mirrordirector.raspbian.org:http:
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/wheezy/main/i18n/Translation-en  Unable to connect to mirrordirector.raspbian.org:http:
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/wheezy/non-free/i18n/Translation-en_GB  Unable to connect to mirrordirector.raspbian.org:http:
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/wheezy/non-free/i18n/Translation-en  Unable to connect to mirrordirector.raspbian.org:http:
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/wheezy/rpi/i18n/Translation-en_GB  Unable to connect to mirrordirector.raspbian.org:http:
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/wheezy/rpi/i18n/Translation-en  Unable to connect to mirrordirector.raspbian.org:http:
E: Some index files failed to download. They have been ignored, or old ones used instead.
