Can anyone help me fix WiFi connection on wlan0
by andrewstillie » Thu Mar 21, 2013 10:15 pm
I am relatively new user with the pi.
I have just installed tightvncserver, after my next reboot I have been unable to connect wirelessly.
When I run the if config command I can only see eth0.
When I run lsusb I can see my wireless adaptor listed.
Can anyone offer some help?
Andy
by docwisdom » Thu Mar 21, 2013 10:17 pm
is wlan0 setup in /etc/network/interfaces ?
by andrewstillie » Thu Mar 21, 2013 11:32 pm
Yes, that is set correctly and unchanged from prior to the reboot.
by Joe Schmoe » Thu Mar 21, 2013 11:54 pm
The most important thing is to do "ifconfig -a".
Without the "-a", it only lists devices that are "up".
Faced with the choice between changing one's mind and proving that there is
no need to do so, almost everyone gets busy on the proof.
- John Kenneth Galbraith -
by andrewstillie » Fri Mar 22, 2013 11:05 am
Is there some way I can undo the install of tightvncserver?
Could this install have have corrupted the WiFi dongle driver?
by andrewstillie » Mon Mar 25, 2013 8:11 pm
Here is a snapshot of ifconfig with the -a.
I notice there is still no IP address....any clues?
by Joe Schmoe » Mon Mar 25, 2013 8:21 pm
Well, you asked why it didn't show up in "ifconfig" and the answer is "because it wasn't 'UP'".
When you do "ifconfig -a", it is there.
Note, incidentally, that in the old days, "UP" and "has an IP address" were synonymous. Nowadays, however, I've noticed that it shows as "UP" even when it doesn't have an IP address. I treat this as an anomaly.
by andrewstillie » Mon Mar 25, 2013 8:25 pm
OK...what else can I try?
by andrewstillie » Mon Mar 25, 2013 8:30 pm
Lol...I need to re-title this post.....Can anyone help me fix WiFi connection on wlan0?
by andrewstillie » Tue Mar 26, 2013 4:08 pm
Is there anyway I can check if I have a wifi connection to router?
ie not a IP Address allocation issue.
by mahjongg » Tue Mar 26, 2013 4:10 pm
andrewstillie wrote:Lol...I need to re-title this post.....Can anyone help me fix WiFi connection on wlan0?
Because you ask nicely... ;)
by andrewstillie » Tue Mar 26, 2013 4:47 pm
My apologies not missing my manners....Please and thank you added to all previous posts. ;)
by jaylongley » Tue Mar 26, 2013 8:27 pm
if your wireless is setup properly and your vnc is too, did you set your tightvncserver to start on boot?
http://www.InstantSupportSite.com/self-help/
