Getting start
by kunming » Thu Mar 14, 2013 8:50 am
Hi everyone,
I have just had my Pi, unfortunately, i have no hdmi supported screen in hand. Is it possible that i connect it to my pc by using a serial wire and minicom? Thanks for help if anyone has any idea.
kunming
by rurwin » Thu Mar 14, 2013 8:55 am
Yes, but you will require extra hardware. There is no RS232 standard serial port, only 3.3V logic signals on two GPIO pins. You need an RS232 buffer to convert them to +/- 12V.
The easiest way to connect to a RaspPi without a screen and keyboard is to use Ethernet and connect using ssh. "putty" would be the app on the Windows side. I assume your Pi is a model B?
by kunming » Thu Mar 14, 2013 9:08 am
Yes it's a model B. And does it work the same on Linux side? Because i'm working in Linux and i'm an absolute newer :oops:
by rurwin » Thu Mar 14, 2013 9:35 am
The RaspPi has ssh already installed. To talk to it you will need a ssh client application on your other computer. For Windows, putty is the usual choice.
You then need to connect the Pi into your network with an Ethernet cable. If you have a simple home network, that probably means connecting it to the router.
Once you've done that, and switched on the Pi, then you can look at the router's web page to find the address it has allocated to the Pi.
You give that address to putty, and it will connect to the Pi.
(It is possible to use WiFi on the Pi, but it needs to be configured, and that is not possible until you can talk to it. It needs a WiFi adapter too.)
by kunming » Thu Mar 14, 2013 11:41 am
rurwin wrote:Yes, but you will require extra hardware. There is no RS232 standard serial port, only 3.3V logic signals on two GPIO pins. You need an RS232 buffer to convert them to +/- 12V.
What exactly does a RS232 buffer mean?
by ghans » Thu Mar 14, 2013 11:47 am
Something like this :
http://www.rhydolabz.com/index.php?main_page=product_info&products_id=302
You might be able to get them even cheaper.
ghans
by klricks » Thu Mar 14, 2013 1:17 pm
Edit: .............. As others have said you need a 3.3V TTL to RS232 converter module.
Another option if you want a full GUI connection is to install xrdp on the RPi and a Remote desktop application on your PC. Requires internet connection to download xrdp to the RPi.
sudo apt-get install xrdp
I have tutorials on Serial and RDP on my web site:
http://64.13.91.137:86/Comp/RPi/Rpi.html
If you have a VGA type monitor then you could purchase a HDMI to VGA adapter.
http://www.amazon.com/gp/product/B007VILC2E/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
If you have an old TV with composite (RCA) then you could use that with just a video cable.
Go here for my RPi writeup. Basic config, Serial Port add-on etc:
http://home.budget.net/~klricks/Comp/RPi/Rpi.html Click web icon on right side --->
by rurwin » Thu Mar 14, 2013 1:48 pm
@klricks, are you sure configuration needs to be done? I've not tried it, but I understand there is a login running on the serial port and it is configured to 115k baud, by default.
by ghans » Thu Mar 14, 2013 2:48 pm
Yeah , i think rurwin is right , too.
ghans
by klricks » Thu Mar 14, 2013 5:40 pm
rurwin wrote:@klricks, are you sure configuration needs to be done? I've not tried it, but I understand there is a login running on the serial port and it is configured to 115k baud, by default.
Yes you are right the config is only needed to convert to a general purpose serial port.
by Jim Manley » Thu Mar 14, 2013 6:10 pm
Once you have an ssh session going to log into the Pi at the command line level and an Internet connection, you can install a VNC (Virtual Network Computing) server on the Pi. This will allow you to remotely log into a Pi graphical user interface (GUI) desktop over a wired or wireless network from any Linux, WIndows, Mac, smartphone, tablet, etc., device after installing a VNC client on the display system(s). One of the more popular VNC implementations is TightVNC due to its speed and minimal resource load on small computers such as the Pi.
A Google search will reveal a plethora of other VNC servers and clients, e.g., http://en.wikipedia.org/wiki/Virtual_Network_Computing Note that you can have multiple VNC connections active from more than one remote system to a single Pi, although that will consume valuable memory and slow the Pi down even more than one VNC connection will (the visual response will always be at least a bit slower than having a display connected directly to the HDMI or composite port).
The best things in life aren't things ... but, a Pi comes pretty darned close! :D
"Education is not the filling of a pail, but the lighting of a fire." -- W.B. Yeats
In theory, theory & practice are the same - in practice, they aren't!!!
by kunming » Fri Mar 15, 2013 10:26 am
Jim Manley wrote:Once you have an ssh session going to log into the Pi at the command line level and an Internet connection, you can install a VNC (Virtual Network Computing) server on the Pi. This will allow you to remotely log into a Pi graphical user interface (GUI) desktop over a wired or wireless network from any Linux, WIndows, Mac, smartphone, tablet, etc., device after installing a VNC client on the display system(s). One of the more popular VNC implementations is TightVNC due to its speed and minimal resource load on small computers such as the Pi.
But the problem is that i failed to connect my PI by SSH even though i have tried every possible ip address. I can do nothing but look at it for now. Help me!!
by Spid » Fri Mar 15, 2013 10:32 am
I am lost, but how have you setup your network (topolgy) ?
I will always assume you are running Raspbian for desktop and Raspbmc for XMBC !
by rurwin » Fri Mar 15, 2013 10:33 am
How are you connecting the wires up? What plugs in to what?
by kunming » Fri Mar 15, 2013 10:55 am
rurwin wrote:How are you connecting the wires up? What plugs in to what?
Nothing special, i power it with the charger, and connect it to my pc by a network wire. And i tried ssh localhost in my pc, it worked. I dont know the PI's ip address but i have tried all the possibilities. I just cant connect to it! :cry:
by RaTTuS » Fri Mar 15, 2013 11:05 am
what OS on your PC?
open a command prompt if windows and type
ipconfig /all
is your PC connected to the internet
plug the network lead in before powering the RPi
do you have a router or a switch that the windows machines plugs into or is it wireless
http://www.catb.org/esr/faqs/smart-questions.html <- ask smart Questions
"That's not right, the badgers have moved the goalposts."
1QC43qbL5FySu2Pi51vGqKqxy3UiJgukSX - Prosliver FTW
by rurwin » Fri Mar 15, 2013 11:06 am
Your PC does not contain a DHCP server, so there is nothing to issue the Pi with an IP address.
Either plug them both into a router, or install a DHCP server on your PC.
by kunming » Fri Mar 15, 2013 11:27 am
RaTTuS wrote:what OS on your PC?
ipconfig /all
I have Linux on my PC.
But I have already install a DHCP server as you said yesterday, it changed nothing. Maybe I didn't configure it well, Linux is little complicate for me. Actually it's not my pc. I'm doing my internship here, so it's little urgent.
by RaTTuS » Fri Mar 15, 2013 11:32 am
on your PC type
ifconfig
what is printed
which linux is on your PC [debian, ubuntu, slackware ?]
is your PC conencted to a network and if so can you plug your RPi into the same network switch
by kunming » Fri Mar 15, 2013 11:37 am
It prints this:
eth0 Link encap:Ethernet HWaddr 00:50:22:e0:11:18
inet addr:192.168.0.1 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::250:22ff:fee0:1118/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:54 errors:0 dropped:0 overruns:0 frame:0
TX packets:4479 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:18468 (18.0 KiB) TX bytes:424711 (414.7 KiB)
Interrupt:23 Base address:0x5000
eth1 Link encap:Ethernet HWaddr 00:30:05:6a:c2:94
inet addr:172.27.13.38 Bcast:172.27.13.255 Mask:255.255.255.0
inet6 addr: fe80::230:5ff:fe6a:c294/64 Scope:Link
RX packets:1243378 errors:0 dropped:0 overruns:0 frame:0
TX packets:833506 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:713771443 (680.7 MiB) TX bytes:70254182 (66.9 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:4459 errors:0 dropped:0 overruns:0 frame:0
TX packets:4459 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:828491 (809.0 KiB) TX bytes:828491 (809.0 KiB)
The switch isn't here so i cant plug it into the same network. I used another network card to work on it.
by ghans » Fri Mar 15, 2013 11:53 am
Just FYI , i'm confident that using a RS232 level converter
and minicom would yield results pretty fast.
ghans
by kunming » Fri Mar 15, 2013 12:13 pm
I agree with you. I have already ordered a converter.
by kunming » Fri Mar 15, 2013 12:15 pm
Finally!!!!!!!!!!!! I succeed in connecting my PI by SSH, thank you all for all these replies!!!!!!!
