MPEG-2 & VC-1 license key queries / issues
153 posts   Page 3 of 7   1, 2, 3, 4, 5, 6, 7
by dottore74 » Sun Mar 03, 2013 12:25 pm
My order #49962. More then 72 hours waiting...
What is average delay?
by Slowhand » Sun Mar 03, 2013 1:41 pm
littlalex wrote:Even Worse - I got my license payment refunded back through PayPal after waiting 72 Hrs+ with a message "out of stock" How can a software license (a text number) be out of stock?!
Littlalex
LOL :lol: Good post!
by rdb » Sun Mar 03, 2013 2:42 pm
This thread is intended to provide an FAQ for any license key ordering issues. Please read the information in this post and only reply if you are still having issues after following the advice given.
The license keys are issued automatically by email at 1AM GMT each day. The email is sent to the address given by the customer as part of order checkout. As the orders are processed automatically every 24 hours it is likely that you will receive your keys within that time frame. If you do not receive your keys then it is likely that it is due to one of the following issues;
Problem: The email address you provided is incorrect (e.g. spelling error, wrong account)
Solution: Email store@raspberrypi.org with your correct email address
Problem: The email sent by the store containing the licenses has been incorrectly marked as spam by your email provider
Solution: Please whitelist store@raspberrypi.org before submitting an order with the store and check your spam filter if you have not received your order.
We aim to deal with all emails sent to store@raspberrypi.org within 24 hours but please allow up to 2 business days during periods of heavy traffic.
If you have not had a reply to your issue from store@raspberrypi.org within 2 business days then please post your issue as a reply to this post. All previous threads concerning license delivery will be closed and merged into this one.
by lometje » Sun Mar 03, 2013 11:12 pm
Received the codes! Thanks; Now it lives up to even more potentials ;-)
by draggi » Tue Mar 05, 2013 1:47 pm
Hi, I have the same issue, had buy a licence on 27 February but don't receive any licence number.
No response from the support ...
Order #49894
Thanks for your help
by draggi » Tue Mar 05, 2013 1:52 pm
Hi I have the same issue. I don't receive any licence number from the 27 February ...
Order #49894
The status of my order is COMPLETED.
Thnaks for your help.
by propellane » Sun Mar 10, 2013 12:12 pm
My number order is #51206. I did not get a response for a week, and two days from store@raspberry.com.
Thank you for your help before.
by lleb » Wed Mar 13, 2013 12:25 am
Liz thanks for all of the great responses in the forum. I have been trying to get my MPEG2 codec to work on my Pi. Sadly we are still having issues. the store basically stopped responding to me earlier this morning so I forwarded you the last e-mail I sent them.
I did receive my codec within the 72hrs. The issue is the code is not properly unlocking BOTH the MPEG2 and WVC1. It is only unlocking the MPEG2 codec. This is causing a major issue with ISO playback via xmbc. This is the ONLY reason I paid for the codec is to play my ISO files of the many movies I have just burned directly to my NFS server.
[kayla@localhost ~]$ ssh pi@192.168.2.203
The authenticity of host '192.168.2.203 (192.168.2.203)' can't be
established.
RSA key fingerprint is 7b:01:b3:4c:8f:71:ff:86:5b:49:1e:51:d9:19:55:11.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '192.168.2.203' (RSA) to the list of known hosts.
pi@192.168.2.203's password:
Linux openelec 3.6.11+ #371 PREEMPT Thu Feb 7 16:31:35 GMT 2013 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue Mar 12 13:43:13 2013
/usr/bin/xauth:  file /home/pi/.Xauthority does not exist
pi@openelec:~$ cat /boot/config.txt
decode_MPG2=0xxxxxxxxxx
pi@openelec:~$ vcgencmd codec_enabled MPG2
MPG2=enabled
pi@openelec:~$ vcgencmd codec_enabled WVC1
WVC1=disabled
redacted my code from above. I have verified multiple times that the code was copied exactly as the initial e-mail indicated.
by Paul Webster » Wed Mar 13, 2013 7:11 am
@lleb
If you ordered both codecs then you should have received 2 activation codes.
However, your config.txt seems to show only one.
What was shown in the email that you received from RPi store?
by lleb » Wed Mar 13, 2013 7:50 pm
this is the exact email less a redacted key:
Thank you for purchasing codec license keys from the Raspberry Pi Store.To enable codecs on your device(s), add the following lines to the config.txt file in the FAT partition of your SD card:
If you want to verify that the codecs are now enabled, the following commands will report their status:
Regards
The Raspberry Pi Foundation
That is all I received. It has now been over 24hrs since I last heard from them and I am still broken.
by lleb » Wed Mar 13, 2013 8:07 pm
also just to be on the safe side I updated the firmware on my RPi, still no love:
[/code]root@openelec:~# /opt/vc/bin/vcgencmd version
Mar 7 2013 19:37:36
Copyright (c) 2012 Broadcom
version 375458 (release)
WVC1=disabled
MPG2=enabled
[/code]
by Paul Webster » Wed Mar 13, 2013 10:48 pm
There should have been 2 lines in the email.
Try a PM to Liz with a link back to your post 2 above this one.
by lleb » Wed Mar 13, 2013 10:53 pm
well that would explain part of it. So if I follow you there should be 2 licenses that I paid for, yet I only received the one.
Thanks, Ill send Liz a PM.
by Paul Webster » Thu Mar 14, 2013 11:12 am
The official way would be to send email to store - see FAQ entry a few posts before yours.
by kthordarson » Mon Mar 18, 2013 9:10 am
Hi, I ordered my license on March 14. Havent received anything yet. Why not?
by rws » Mon Mar 18, 2013 11:27 pm
I ordered an MPEG-2 license key over a week ago (as a guest) and received
a confirmation of my order #53170 in my inbox, but I haven't received a key.
I've also received no reply to my inquiry from 4 days ago.
(I've checked my spam folder, too.)
by mdferket » Thu Mar 21, 2013 10:17 am
ordered incompetent Order # 55589, sent mail and message left in the store raspberrypi no response, I wait until Monday, March 25 and then I paypal ordering refund.
The worst part is that there is not responding to mail and messages.
by mdferket » Thu Mar 21, 2013 10:19 am
done
by jiggeligge » Mon Mar 25, 2013 10:19 am
Hi there,
I still did not receive my license key.
Could you please check what went wrong?
#56701.
by festerthaysen » Mon Mar 25, 2013 11:25 am
Oder: 56634 and order: 56605. I have not received my license keys yet. You write you will send out license within 24 hours? I have checked my spam, however nothing has arrived to my email. Hope to hear from your soon....
by dgrs » Mon Mar 25, 2013 12:03 pm
Order (#56572) - Still not received my key. How long does one have to wait for this? If you sent it every 24 hours then I should have receive my key 2 days ago.
by Paul Webster » Mon Mar 25, 2013 6:57 pm
Did you (previous few posters) send a query email to store@... as described in the mini FAQ above?
viewtopic.php?t=35818&p=317244#p301491
by rpowell002 » Sat Mar 30, 2013 7:53 pm
I ordered both license keys about a week and a half ago and never got a response. I chose to checkout as a guest, so I'm not sure if that's the problem or what, but I emailed the store email address and didn't get anything either.
by bonix2001 » Tue Apr 09, 2013 4:17 pm
HI,
at March.31 I ordered a MPEG2 license key + a T-shirt as #59304
Due to ester weekend the order was paid a April.2 but until now I neither received a order status update (besides the order confirmation to my email address) nor an answer to my inquiry to store email address yesterday.
So any kind of update is really appreciated...
best regards
Ralf
by jojj0 » Wed Apr 10, 2013 11:27 pm
I ordered both an MPEG-2 and a VC-1 license on April 4th but have not received anything. I even checked my spam folder. My order (#60495) was placed as a guest. I sent an email to the store email address a few days ago, but have not received a reply. Any help would be appreciated.
