cups on raspbmc
by onkeltobi » Sun Feb 17, 2013 4:08 pm
i tried installing cups on actual raspbmc.
I can start cups manually, but it seems that cups isn't configured correct.
pi@raspbmc:~$ sudo dpkg-reconfigure cups
/usr/sbin/dpkg-reconfigure: cups is broken or not fully installed
I also tried to reinstall some packages, but still the same error. Any hint for me?
Regards,
Tobi
by Cloudcentric » Sun Feb 17, 2013 5:45 pm
Have you made yourself a member of the LP Admin Group ?
usermod -a -G lpadmin pi
I know everything about nothing"
by onkeltobi » Sun Feb 17, 2013 6:59 pm
thanks for your answer.
I did that step.
Now i tried a comletely fresh installation, but result still the same..
update-rc.d: error: insserv rejected the script header
dpkg: error processing cups (--configure):
Tobi
by onkeltobi » Mon Feb 18, 2013 6:52 pm
now cups is installed. I removed all and installed phys-swapfie.
After that installation of cups worked, but now i have the same problem with avahi-daemon and libnss-mdns packages...
any ideas?
