Card will boot with raspbmc but not openelec or xbian
by bcinpgh » Sat Feb 16, 2013 11:14 pm
My 8gb class 4 card works fine but I purchased a 16gb class 10 ( one that was on the wiki list of approved cards) and it works fine with raspbmc (and has provided a SIGNIFICANT performance boost--- from barely usable to very nice). However when i try to boot up with either openelec or xbian its as if the card is blank, the pi doesnt register it. Im using the same image writing / card prep procedures... Those 2 distros will boot with the 8gb card.
Any thoughts on how I can use the better card and openelec? Seems strange that it will boot with one system but not another. It would be one thing if it wouldnt boot with anything...
Id really rather use openelec over raspbmc...
Thanks!
by Mobius » Sun Feb 17, 2013 4:13 am
Try formatting the new SD card and then imaging it. You may have to delete one of the partitions and then expand the other to fill the whole card before formatting. I've used the free EaseUS Partition Magic program to do that.
by Cloudcentric » Sun Feb 17, 2013 6:59 am
In Linux I use GParted to remove partitions, then create one FAT32 partition prior to DDing the .IMG
If you are using Windozy there is a Live CD http://gparted.sourceforge.net/livecd.php
I know everything about nothing"
by bcinpgh » Sun Feb 17, 2013 1:37 pm
Thanks for the replies. Yeah, i used the raspbmc installer function to "make card formattable"or whatever ( makes it so the full space of the card shows in windows for formatting) and then formatted it in windows.
Im game to try your suggestions but what ought the proper partition structure look like? It sounds like im gonna need to manually create them.
Thanks!
by Cloudcentric » Sun Feb 17, 2013 4:11 pm
Use the standalone Image http://www.raspbmc.com/download
"Standalone Image – If you just want a standalone image that can be booted without a network connection for initial setup, then you can get the latest image here. This image will resize your SD card partitions to use the full size of your card on bootup. This image should only be used as a last resort, say if you live in a rural area and are planning to download the image at work."
by bcinpgh » Sun Feb 17, 2013 5:48 pm
Thanks but its raspbmc im not having trouble with. I wonder if its not the installer changing the card in such a way that when i try to write the openelec .img (after restoring the card size amd formatting) theres something not right. Like u guys were saying about partitions...
On a freshly formatted sd card, what should the partitions look like?
by Cloudcentric » Sun Feb 17, 2013 5:55 pm
by bcinpgh » Mon Feb 18, 2013 11:15 am
I have tried that but it doesmt help. Thats what Ive been using to write the openelc image....
by bcinpgh » Wed Feb 20, 2013 7:15 pm
Anyone else? Additional thoughts?
by craler » Thu Mar 21, 2013 11:08 pm
I have the same problem.
Rasbmc (Autoinstaller) works but Openelec not!???
for Openelec i tried following methods:
- dd command, on OS X (sudo dd bs=1m if=~/Downloads/2012-10-28-wheezy-raspbian/2012-12-16-wheezy-raspbian.img of=/dev/rdisk1) The Terminal even says that its completely transfered?
- Raspberry PI SD Installer OS X, https://github.com/RayViljoen/Raspberry ... aller-OS-X
- RPi-sd card builder v1.2, on OS X
- Win32DiskImager, on WinXP
For both upper methods i used the unpacked image.
Please can u help us?
by bcinpgh » Fri Mar 22, 2013 12:54 pm
Yep, I'm still having this problem...
craler wrote:I have the same problem.
by craler » Sat Mar 23, 2013 5:09 pm
Hey now Openelec works!!!
It looks like the image was not fully correct.
for me the latest image from here worked
http://openelec.thestateofme.com/official_images/
