No sound through USB speakers
by Mcbeaver » Fri Feb 08, 2013 1:46 pm
Hi there.
I've run into a problem with my sound on the raspberry.
I picked up a pair of Edifier R600USB speakers today and thought i'd give them a go.
The problem though is that I can't seem to get any sound through these.
The speakers are powered from a powered usb hub so I think the power should be alright.
I believe i have messed up some settings which would make them work (most likely in /etc/asound.conf)
Here are 4 images of how it looks.
http://imgur.com/r4EDBAW,vQWhpaL,2rzJmYo,NUrajHI#0
It seems like the raspberry finds the speakers but are unable to process sound through them because of hwparams?
Any help would be appreciated.
by redhawk » Fri Feb 08, 2013 2:50 pm
Does aplay -l show your device as listed??
You cannot simply plug in a USB audio device an expect it to play the music app needs to be configured to access it.
What program are you using for playing audio??
Richard S.
by Mcbeaver » Fri Feb 08, 2013 2:55 pm
Yes, as shown in one of the pictures, aplay -l listed the speakers correctly.
I managed to solve the problem myself though through some testing, apparently everything was set up correctly and it scared the hell out of me when sound came out when i tried "speaker-test -c2" (went through the list of -c0-> in desperation).
I had only tried the wrong outputs (which looked right i thought).
Got sound through squeezeslave when I selected the "sysdefault" option somewhere in the middle of options instead of "USB Audio Device: USB Audio" or default.
by blacknoise » Wed Feb 20, 2013 10:38 am
Thanks for the great input! I'm trying to get the R600 working with mpd.
The speaker-test went just fine with the -c2 flag, but I don't know which settings to use in mpd.conf.
Aplay also doesn't work. Any ideas?
by ski522 » Wed Feb 20, 2013 12:32 pm
blacknoise wrote:Thanks for the great input! I'm trying to get the R600 working with mpd.
Have you configured MPD to work with alsa? "sudo nano /etc/mpd.conf" and make sure you have the following:
audio_output {
        type            "alsa"
        name            "My ALSA Device"
        device          "hw:0,0"        # optional
        format          "44100:16:2"    # optional
        mixer_device    "default"       # optional
        mixer_control   "PCM"           # optional
        mixer_index     "0"             # optional
by blacknoise » Thu Feb 21, 2013 10:20 am
Hi ski522,
thanks for the reply, my config looks just like that.
After another hour of trial and error I finally found the cause. Kind of awkward, but the mpd playlist was empty. :roll:
I had to add the files from the music folder first...
Initially the sound was very distorted, but after switching to USB 1.1 I'm happy with the result.
Greetings
blacknoise
