Hexxeh image doesn't boot
by deltalimablahblah² » Thu Jan 24, 2013 6:00 am
I downloaded the r3 Hexxeh image from here
http://www.raspbian.org/HexxehImages
I copied it with w32diskimager on 4GB SD card. This SD card works 100% ok with official Raspian os. But if I copy Hexxeh r3 with no errors it doesn't boot. No yellow lamp flickering. If I put RPI to TV via HDMI absolutly nothing comes up. If I put SD card to PC I can see and open the boot partition.
So, what's the matter with Hexxeh image?
Some background for you: I'm looking for a very small os without X server, browser and the whole stuff. Just bash and wifi/ethernet stuff. Which image fits the most?
by Spid » Thu Jan 24, 2013 7:47 am
Arch Linux Arm aka alarmpi http://www.raspberrypi.org/downloads
It is by default a Command line Distro, but ethernet and wpa_supplicant (wireless) both included.
I will always assume you are running Raspbian for desktop and Raspbmc for XMBC !
by deltalimablahblah² » Thu Jan 24, 2013 9:06 am
Hi Spid,
thank you very much for the information. But: I like apt a lot. I have no knowledge about Arch LX packet manager...
BTW: this morning I tried this Image, too:
http://www.linuxsystems.it/2012/06/rasp ... mal-image/
It wasn't booting, too???!!! I wrote this image with dd on working SD card as described. If I start RPi up with this card nothing - in words nothing - happens.
What did I do wrong?
by Spid » Thu Jan 24, 2013 9:30 am
Arch package manager https://wiki.archlinux.org/index.php/Pacman
Raspbian can be booted to Cli, you do net need to have the LXDE GUI, it can be removed via apt-get..
by deltalimablahblah² » Thu Jan 24, 2013 10:04 am
Hi Spid,
booting to CLI is my first choice. I don't auto boot any X window manager. And I don't want to install the full bloated Raspian and then deinstall all of the unwanted packages actually. But if I have to do so....
Other way it to learn Arch LX aka packet manager. But it seems that file strukture is different from Debian style strukture. Am I right? Since years I'm on Ubuntu/Debian os. So I could be hard to learn Arch LX ??!! But if I have to do so (part II)....
But I don't know why minimal images don't boot on my RPi...
by drgeoff » Fri Jan 25, 2013 12:20 am
If you are using a 512 Mbyte RPi you must have a firmware later than about October 2012 (I don't know the exact date.) The larger RAM chip on the 512 versions is not supported (= won't work) with earlier firmwares. I don't know the age of hexxeh r3 but the filename of raspbian_wheezy_20120608.img.7z which is downloadable from http://www.linuxsystems.it/2012/06/rasp ... mal-image/ suggests it was put together in June 2012 which was months before a firmware for 512 Mbyte RPis was in circulation.
Update. I looked at the page given above for hexxeh r3 and noticed:
Quote:
Changes from the previous r2 image are as follows:
Updated to the latest Raspberry Pi firmware and kernel as of 13th May
Endquote.
So that is much too old also.
by deltalimablahblah² » Fri Jan 25, 2013 10:17 am
Hello drgeoff,
thank you for this information. I didn't thought about this fact. Yesterday I got a minimal Image to work:
http://www.cnx-software.com/2012/07/31/ ... pberry-pi/
Ok, this image is dated july of 2012. But after installtion/update/ugrade I did rpi-update by Hexxeh:
https://github.com/Hexxeh/rpi-update
So I hope to get the latest stuff with his update script. I'm just too lazy to rebuild a fully bloated Rapian through deinstallations...
