xbmc-rbp-git fails to load in
by scorpiove » Thu Jan 17, 2013 11:56 pm
Hi everyone I am using the archlinux-hf-2012-09-18 image of arch linux, and I installed xbmc-rbp-git with pacman. But when I try to run xbmc I get this error.
/usr/lib/xbmc/xbmc.bin: error while loading shared libraries:
libcdio.so.13: cannot open shared object file: No such file or
directory
Before that I was gettin this error which was fixed wtih symbolic links
libGLESv2.so: cannot open shared object file: No such file or
directory
Whats also strange is I get this output after everything as well
ldconfig: File /usr/lib/libgdk-1.2.so.0.9.1 is empty, not checked.
ldconfig: File /usr/lib/libgdk.so is empty, not checked.
ldconfig: File /usr/lib/libgtk.so is empty, not checked.
ldconfig: File /usr/lib/libgtk-1.2.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgtk-1.2.so.0.9.1 is empty, not checked.
ldconfig: File /usr/lib/libgdk-1.2.so.0 is empty, not checked.
I installed and removed gtk with pacman so maybe thats why im getting the last error. Any help would be greatly appreciated! :)
by pepedog » Fri Jan 18, 2013 1:29 am
Archlinux arm has a little problem with glibc at the moment, bit of a bugger which I'm sure will be fixed soon
2ways of running
export LD_LIBRARY_PATH=/opt/vc/lib
xbmc
Or
LD_LIBRARY_PATH=/opt/vc/lib xbmc
So sorry for inconvenience, reported upstream. ld cache is being ignored
by scorpiove » Fri Jan 18, 2013 3:00 am
Thank you, I can't wait to get home now and try it. :)
by komodo » Fri Jan 18, 2013 7:39 am
The glibc/ld cache issue is not new; it's the same for the last few weeks.
The libcdio is brand new though. Here it is upstream https://bbs.archlinux.org/viewtopic.php?pid=1218896
Long story short, it looks like libcdio was updated upstream, and xbmc-rbp-git is linked against an old (now nonexistent) libcdio.so.13 now.
Bug will probably persist until the xbmc package is rebuilt against new libraries.
Where would be best to report this?
